Well, its sad day for us all... Well, mainly me. But still. I'm sure you'll all share my depression. lol.
I've decided to sell The Stag. The $12k loan I've still got hanging over my head is really hindering me financially since I'm just about to move into a new place. So I need to sell The Stag, pay off my loan and downgrade my ride a little.
I've advertised for $24k, which I know people will think is a bit steep for an RS4S, but fact of the matter is, I'm not in a hurry to get rid of it, so I'm happy to wait around for a buyer, and with all the mods I've done do it, I think its worth at least $20k.
As a bit of a consolation prize however, I do plan to get a series 7 RX7 as my new ride :ermm:
Will definitely miss The Stag though.
Well, here's the link if you want to have a gander:
http://www.carsales.com.au/used-cars/priva...amp;distance=25
Edited by Unbalanced
https://www.sau.com.au/forums/topic/313148-selling-the-stag/
Geez bud. Thats steep. But sorta justified. Msports180 has one of the best deals goin atm in WA. There is a sea of RS4s and 260s for sale interstate. Must be good. Looked at your link not much info.
List of mods and parts used pleez. :blink:
Edited by dirtyRS4
Was a good deal! Just sold it!
..You took your stagea on the beach lol...
Yeah when I see photos of people trying to sell their car with photos of it on the beach makes me think hmmmmm... Id probably prefer photos of a car on the track than on the beach... But in a for sale ad... seriously?
It spent a day on the beach last summer. What of it?
The undercarriage copped a good hose down immediately afterwards. Was a sweet vehicle for the beach actually. Had the beats cranking, the deck chairs set up, esky in the back. Loved it! Had quite a few people approach me and ask about it too :)
Those poor sheltered creatures at Wallaroo had never seen one before. Haha.
Ad updated:
Carsales - '99 Nissan Stagea RS4S
List of mods I can think of right now:
- FMIC with custom piping
- Bosch 023 Fuel pump
- 3" straight-through exhaust (gives a very nice rumble, but can be driven very quietly when required)
- 3" dump pipe
- Nistune board (was tuned prior to the dump pipe, so with another tune could probably see even more kw at the wheels)
- Custom steel front lip
- BC coilovers (Spring rates: Front= 8.0kgs -- Back= 6.0kgs)
- Rear swaybar
- 18x9 wheels with +30 offset (decent tyres all round)
- 1" bolt on spacers front and back
- 6mm slip on spacers on rear
- Pod filter
- Stock BOV removed (gives a nice, yet modest, flutter)
- Turbo timer
- Bleed valve
- 40000k xenons
  • 1 month later...
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
