So I had been in the market for a paddock-basher and stumbled across a front-end smashed r31 silhouette going cheap. Of course as soon as the cash left my hand I developed an attachment to it and now I'm not prepared to sacrifice it. I'll have a go at repairing it instead.
Should have bought a hyundai...
https://www.sau.com.au/forums/topic/313183-i-just-bought-an-r31-silhouette/
that was supposed to be cop
Oh, I see. someones done that funny thing to the computer that when you type in certain words they show up as another. A popular trick at my work. I'll try this P I G. Very funny by the way
You will get a heap of help for parts from these two sites as well:
www.r31skylineclub.com
and
www.classicskylinesaustralia.com.au
Funny thing about R31's and how we get all wound up and passionate about them.
Have been productive pulling off and scraping damaged parts, and less so with the pics.
I need a complete front end: bonnet, bumper, front spoiler, driver's side h/light and panel, aircon fan and irritatingly, radiator (turns out the engine fan has nicked it after all.)
I also need to pull the radiator support forward an inch, and are thinking of doing this with the assistance of a chain and sturdy tree.
Still keen to repair, but not interested in spending a fortune. Anyone got a basket case series one R31 or spotted one at a local Vic wrecker?
The rest of the car is lovely and I've have had a pleasant week poring over service history and getting acquainted with modern features I've never played with before like central locking and the Nissan headphones for the rear passengers.
I have a month of permit to either get the car fully rego'd, club rego'd or retire it to the bush for punishment/stripping.
There are PLENTY of shite bags here to pillage parts from
http://motamota.r31skylineclub.com/index.php?board=26.0
there is a parts section too.
very common to see a slapper go for $500.
number one rule though, im sorry guys, but do not buy anything from south australia, there are so many dodgey sellers ther its near impossible to moderate.
if they are a well-known member then go for it, but still take it easy
Wow... that is a ton of cars. Will stick to Victorian sellers, out of convenience more than anything.
slip over to Center rd wreckers, and Jollys a few good front ends there, you can even use S3 front guards,
is the car auto or man?i may have a radiator, maybe i cant remeber if i chucked it out
Man this is embarrassing... I can't find the parts section.
    • Thanks for the info GTSBoy, legend. If there is no downside i'll likely just get the larger bosch units because why not... I remember hearing stories about people washing their bores with fitment of too large injectors way back when, which i guess has made me shy about it now. But happy to know it shouldn't be an issue. Ozdavroz, the little rb20 is a lot of fun- now that i have a little extra funds and time i am very glad to be tampering with the ol girl again, after so long. More RB20's on the road the better. Cheers, Rowdy
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
