Very nice intake plenum and has the provision to run two fuel rails (12 injectors) currentley runs one rail, save yourself some coin.
HKS rail (not shown) is brand new and never used.
$800 or best offer for pair
will sard injectors fit in the provided fuel rail?
mite be interested in both
also do these plenums realy make much of a difference over a standard 1?
ive read alot of posts where people say that they dont
Sard injectors fit no dramas. Depends on your turbos, we have back to back comparo with the stock plenum and the K5-660R and @ 400rwkw the EGTs were far more consistant between cylinders with the greddy, i have refitted the smaller rear turbo housing so power will be down to around 350rwkw and at that power it is overkill... plus it is too slightly too big for the s13 engine bay.
  • 2 months later...
  • 4 weeks later...
how much for hks rail
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
