hey guys just got a hi-flow cat in my R34 (my piping is standard but it does have a cannon on the back) and now my car sounds like it has a freakin bee buzzin around in the exhaust :)
i hear that i should get a 8" cross flow resonator or somthing like that? would this part fix my buzzing problem! it really really really sounds disgusting my car now :(
also instead of making two threads ill ask another question here.. i just got my R34 converted from a tiptronic to a manual and im pretty unimpressed main reason being my revs take forever to climb like i mean seriously forever.. my fathers mazda 3's revs climb pretty much at the same pace... i know cause its an n/a bla bla bla but this is seriously slower than average, my question is how do i get em to go up faster (with mods) i can hear air gushing (almost as if theres a hole somewhere) right above my drivers seat and no its not from my vents could this be my problem?? also would extractors help a little bit in the response?
cheers
Edited by noely1
https://www.sau.com.au/forums/topic/313221-buzzing-noise/
by the revs rising, you mean that it is slow to accelerate? or just if you sit there on the spot and rev it the revs increase slowly as well? if it is the second one, then i'd check the timing to see if it has been played around with.
also if you are using the auto ecu then it is probably running on the neutral maps as the gearboxes have a switch in them that tells the ecu whether you are in gear or not which can alter the mapping.
https://www.sau.com.au/forums/topic/313221-buzzing-noise/#findComment-5147191
i mean that like i'll be trying to floor it and the car will be screamin its guts off prety much soundin like its goin real fast but the revs arent climbing high at all.. like its not at the point where it goes like a snail its just ive been in a lot of skyline non turbo's and ive never seen one climb this slow... but no i dont mean just sittin there and reving it i mean whilst moving.
and yes i am using the auto ecu after i converted it..
also in relation to my first question would a resonator help me wit that buzzing noise??
cheers for the response mate!
Edited by noely1
https://www.sau.com.au/forums/topic/313221-buzzing-noise/#findComment-5147934
also took the car for a spin to pick up a friend like 5 mins away from me and in corelation to that air noise i spoke about.. when teh radio isnt on and i can really listen the noise that i described as air gushing out somewhere is really noticeable. sounds like a vacuum!! it sounds like its coming straight out from the drivers side vent (but its obviously not) as ive opened and closed teh vent etc and the noise is stil the same opened or closed.. i got a mate to listen from underneath cause the sound is only under acceleration and cant hear anything underneath...?
https://www.sau.com.au/forums/topic/313221-buzzing-noise/#findComment-5147938
i had that crap buzzing aswell, mainly when i first turned the car on, took it to the mechanic and had needed a new bracket and changed the resonator and weld it back to the piping to fit, sounds nice now and no buzzing at all. cost about $350 for it.
https://www.sau.com.au/forums/topic/313221-buzzing-noise/#findComment-5155154
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
