1995 R33 GTS-4 AWD Skyline Rare Model
all pics at http://www.boostcruising.com/forums/index....=538848&hl=
Was $12000 Now $10500 Not Negotiable With New White Wheels With Good Tread And OMP Suede Steering Wheel Price Will Be $11250
will throw in rims currently on the car with good tyers at no extra cost
willing to swap for something that can drift and is street legal of the same value
POSITIVES
*RB25DE (VCT) (110rwkws)
*5 Speed Manual
*R33 GTR DriveTrain
*Atessa 4WD System So Its Not 100% 4WD. Mainly Rear. Once You Loose Traction Then Front Wheels Kick In. On Dash It Shows SLIP 7 4WD.
*Factory Rear Active-LSD option very rare and good
*Slip Torque Plug Located In Boot ( To Make AWD to RWD )
*K&N Panel Filter
*FWD LSD
*Advanced Timing ( 16 BTDC )
*95000kms
*KYB Gas Shocks
*Greddy Strut Brace
*Rebuild Gearbox
*Exedy GTR H/D Clutch Just Installed With Machined Flywheel
*Full Power Options : Windows, Mirrors & Steering
*ABS
*Disc Brakes Front & Rear
*Castrol VMX 80 Gearbox Oil
*BF Goodrich Tyers on the front with about 75% + Tread Left
*1 Faklen and 1 Michelin On Rear Both With 75% + Tread Left
*2.5" Exhaust Cat Back
*Rego Till June
*Fully Imported And Complied in 2007
*17" Lenso Rims (Only 3)
*One 17" Starcorp Rim
*Standed Hight King Springs On Front (just Stiffer)
*Cut Springs On Rear Will Come With Pair Of Lovelles
*Keenwood Head Deck
*Genuine Nissan Skyline Floor Mats
*Only Put In 98 Vortex From Caltex
*comes with 15" kicker sub but no amps
*4x 6" brand new 2 way pioneer speaker
*brand new genuine OMP suede steering wheel with yellow stitching
more info about the 4wd at: http://en.wikipedia.org/wiki/ATTESA
ATTESA E-TS system is used in the following models:
* R32 and R33 (1989-1997) GTS4 Skyline
* GT-R - 1989–2003
* Nissan Stagea
* A31 Cefiro
* Infiniti G35x/Nissan Skyline (V35 & V36)
* Infiniti M
* Infiniti FX
* Infiniti EX35 (with Active Brake Limited Split for side-to-side torque split, as needed)
* Nissan Fuga (Known as Infiniti M in export markets)
This Car Is a Great Car, Drives Beautifully, Handles Excellent and Goes Really Good and Its P Plate Legal
NEGATIVES
*Has Scratches over it
*Rear Bar Touched Up In 1 Corner
*3 Small Dings
*Small Rust Occurring on Rear Wheels Arches
*front bar has scratches
*Other then that nothings really wrong with it
Edited by niiko101
Your link to boostcruising is down maybe this will help the sale http://www.boostcruising.com/forums/index....howtopic=538848
woops thanks for that
Edited by niiko101
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
