Stagea Supergt Safety Car
someone remind me again why they stopped making Stagea's!!!!
Oh thats right......yet another correct marketing design from the Nissan marketing team.....
"Let's produce a car that we will only sell in Japan and when we don't sell enough we will cut it from our line up" :cool:
Look Craig, its a 250rs with nismo sticker kit. :cool:
lol @ Nismo stickers... at least they aren't faded (cheap shot!), but there is a "t" there mate.
That safety car is actually a complete Nismo M35.
Bodykit, exhaust, wheels, suspension, air filter, ECU, brake pads etc.
Surprised to see such recent pics of it actually since the only pics I had (have?) of it are from 2002.
i dont rekon its not a genuine nismo s-tune, thats why
yes it might have all the genuine stuff on it, but its not from factory
Edited by zei20l
I am confused by your double negative mate... so you are saying that you think it is genuine S-tune yet doesn't have all the Nismo gear on from factory? :cool:
I have some thing to say to both Victorian lover boy's here.
White.....very common!
Pascal metallic blue.....ahhh G.....A......Y!
well I am funny....to me :)
Thats me, common. :) Thanks for the compliment Nismo boy. :)
You finally awake?
well I am funny....to me :blink:
You don't like the dark blue, Craig? Seriously? I think it's the nicest colour I've ever seen on an M35, especially after seeing bbenny's one when we had the meet-up at your work car-park.
lol sorry cam, i was clearly not thinking when i typed that
and no, i dont believe its a factory nismo optioned car. however, it has genuine nismo parts fitted post purchase
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
