ok, so i went to change the plugs yesterday. had about 2 hours of light left so it was always a stupid idea, but me in my ambition just went for it.
took the cover, various hoses and electrical plugs off and started unscrewing the 8 allen key screw things holding the cover on the plugs. got to the end, and unbelievably, the last 2 had had their allen key thread stripped. so what was meant to fit to fit the key was circular.
so after spending an unjustifiable amount of time fiddling desperately with allen key and pliers, gave up, and put it back together.
spoke to a mechanic this morning who said i should use a chisel and hammer to turn it. yay, that can't go wrong at all.
so yeah, thoughts? suggestions?
thanks in advance
https://www.sau.com.au/forums/topic/313301-stuffed-bolts-on-spark-plug-cover/
Hammer and chisel to hammer it out!! ??? Maybe these are the only tools he can use properly.
Is the socket in the head 'completely round'? Sometime you can get away with tapping (gently) an imperial hex driver that is just slightly bigger than the metric size. By hex driver I mean one of the attachments that you find in those screw driver sets you can get. Alternatively get an imperial allen key and cut it down. The you have something to grip onto with vice grips etc.
OR
If the top of the head is raised above the plastic enough you can use a dremel with a small circular blade to cut a slot across the top of the bolt then use a flat blade screw driver to turn it out.
OR
If you are confident enough you could drill the head out so that you can remove the cover. Then you should have better access to what remains of the bolt and use vicegrips to turn it out...
Good luck with it...
thanks for the replies guys, feel a bit better about it now. was never really confident in belting a chisel in the engine bay anyways lol.
so if i drill/grind the head off, how much access will i have to the bottom of the screw?
little to none. u will be able to get the cover of but getting the the remainder of the bolt out of the head will be a pain in the ass.
i had the same problem with mine. dont cut anything u need an assortment of flat head screw drivers and a hammer. first try to hammer a flat head that is slightly larger than the alan key hole so that u can un screw it or if that dont work get a small flat head and get it in-between the outside of the bolt and the cover and hammer away what ur trying to do is just get the bolt to turn a little bit so that the first method i said will work.
grinding and cutting or drilling will be difficult with the bolts being at the back
ok mad082 feel free to under mind my post now :)
i had a similar issue with an allen key bolt on my boss kit recently. thread was stuffed, and the hex became rounded in my efforts to get it out.
i used one of these bits. nice an tight, or slightly too big, and hammer it in there. it should grab enough for you to unscrew the bolt.
Edited by Munkyb0y
thanks for all the feedback guys. i got talked into trying an "easy out" screw thing. it was like a reverse drill bit. anyways, under surprisingly little drill pressure the top of the screw just sheared off the rest of the screw. And since i'd lost one i gave up and just drilled out the other one. i'll have a look at what's left on the weekend when i actually change the plugs.
not sure what i can do about the stubs, but its probably not worth bothering with.
thanks for the info, there's definitely a lot of options if this happens again
cheers
Yep do what Paul suggested and cut a slit into the head for a flathead to go in. Alternatively, weld a cheap allen key to the bolt head and turn.
I'm thinking of leaving my cover off permanently because it's a pain in the ass removing the intake everytime I want to access the coils. I'm just concerned about dust/oil collecting in there.
i ran mine without the cover on. it lets the heat escape from the coils better so they last longer. as for keeping water out, i degreased my engine with the cover on and was carefull with where i was spraying the hose not to spray around the cover as i knew water would still get in. i still managed to get enough water in there to cause a bad misfire which actually took longer to go away because when the engine heated up and started to boil away the water the steam couldn't escape very well.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
