ok, so i went to change the plugs yesterday. had about 2 hours of light left so it was always a stupid idea, but me in my ambition just went for it.
took the cover, various hoses and electrical plugs off and started unscrewing the 8 allen key screw things holding the cover on the plugs. got to the end, and unbelievably, the last 2 had had their allen key thread stripped. so what was meant to fit to fit the key was circular.
so after spending an unjustifiable amount of time fiddling desperately with allen key and pliers, gave up, and put it back together.
spoke to a mechanic this morning who said i should use a chisel and hammer to turn it. yay, that can't go wrong at all.
so yeah, thoughts? suggestions?
thanks in advance
https://www.sau.com.au/forums/topic/313301-stuffed-bolts-on-spark-plug-cover/
Hammer and chisel to hammer it out!! ??? Maybe these are the only tools he can use properly.
Is the socket in the head 'completely round'? Sometime you can get away with tapping (gently) an imperial hex driver that is just slightly bigger than the metric size. By hex driver I mean one of the attachments that you find in those screw driver sets you can get. Alternatively get an imperial allen key and cut it down. The you have something to grip onto with vice grips etc.
OR
If the top of the head is raised above the plastic enough you can use a dremel with a small circular blade to cut a slot across the top of the bolt then use a flat blade screw driver to turn it out.
OR
If you are confident enough you could drill the head out so that you can remove the cover. Then you should have better access to what remains of the bolt and use vicegrips to turn it out...
Good luck with it...
thanks for the replies guys, feel a bit better about it now. was never really confident in belting a chisel in the engine bay anyways lol.
so if i drill/grind the head off, how much access will i have to the bottom of the screw?
little to none. u will be able to get the cover of but getting the the remainder of the bolt out of the head will be a pain in the ass.
i had the same problem with mine. dont cut anything u need an assortment of flat head screw drivers and a hammer. first try to hammer a flat head that is slightly larger than the alan key hole so that u can un screw it or if that dont work get a small flat head and get it in-between the outside of the bolt and the cover and hammer away what ur trying to do is just get the bolt to turn a little bit so that the first method i said will work.
grinding and cutting or drilling will be difficult with the bolts being at the back
ok mad082 feel free to under mind my post now :)
i had a similar issue with an allen key bolt on my boss kit recently. thread was stuffed, and the hex became rounded in my efforts to get it out.
i used one of these bits. nice an tight, or slightly too big, and hammer it in there. it should grab enough for you to unscrew the bolt.
Edited by Munkyb0y
thanks for all the feedback guys. i got talked into trying an "easy out" screw thing. it was like a reverse drill bit. anyways, under surprisingly little drill pressure the top of the screw just sheared off the rest of the screw. And since i'd lost one i gave up and just drilled out the other one. i'll have a look at what's left on the weekend when i actually change the plugs.
not sure what i can do about the stubs, but its probably not worth bothering with.
thanks for the info, there's definitely a lot of options if this happens again
cheers
Yep do what Paul suggested and cut a slit into the head for a flathead to go in. Alternatively, weld a cheap allen key to the bolt head and turn.
I'm thinking of leaving my cover off permanently because it's a pain in the ass removing the intake everytime I want to access the coils. I'm just concerned about dust/oil collecting in there.
i ran mine without the cover on. it lets the heat escape from the coils better so they last longer. as for keeping water out, i degreased my engine with the cover on and was carefull with where i was spraying the hose not to spray around the cover as i knew water would still get in. i still managed to get enough water in there to cause a bad misfire which actually took longer to go away because when the engine heated up and started to boil away the water the steam couldn't escape very well.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
