Hi all.
I've been building an R32 skyline up for over a year, I bought it as a shell and have done the following to it.
Resprayed in Lamborghini Grigio avalon (a darkish grey metallic), and it's the sunroof model
Fitted an Origin Streamline bodykit (full kit)
Have an M-Spec kit painted up in same colour (full kit)
Fitted an RB25DET Neo + R34 gearbox/clutch etc. The motor has done 64,000km and runs on the stock R34 ECU.
Put R33 GTR Brembo brakes front and rear, with new rotors on the rear, new brake pads all round
Got Volk GT-C rims with near new tires, 18 on the back 17 on the front
Fitted a Blitz return flow intercooler
Strut braces front and rear
It is nearly finished, just requires the windows to be put in, new quarter panel windows to be bought and a wheel alignment.
I've applied for and received approval for the engine conversion but it needs to have an emissions and noise test before final registration with the new motor can be given (however, it is currently still registered with the original RB20).
My problem is that my wife and I had our first child two weeks ago and she's now not working, so I can't afford to finish the car off and drive it like I wanted to. I may have to sell it as it is.
What sort of value would I be looking at if I sold it as it is?
https://www.sau.com.au/forums/topic/313319-my-r32-build-please-advise/
i am with Damo on this.....prob around the $15K mark maybe higher or lower depends on the haggler and how badly you need to let it go.....also some pics of the build would be nice....as it sounds like a mean build
It will also need a full regency inspection for the engine conversion.
i thought you dont need to go to regency for engine conversions, all you needa do is tell transport SA or whatever its called these days? correct me if im wrong
My 26 conversion had to have a full inspection, any chance in engine type should have to be inspected. If your just swapping an RB20 for another RB20 then you would probably just need to tell them. Things may have changed since my car went through though.
Edited by DSTROY
i put rb25 in r32 and i just had to fill out a form sayin the engine details about it so i guess it dosent need to go through, hope i dont get a call saying i have to go through lol
must be a new thing, my car was done in about 2006/7.
Hey guys, thanks for your input. I will put up some pictures if you like, I'll resize them and do it tonight.
DSTROY, thanks for the hint, I'm sorted with Regency/Inspections. I had to apply using the form Craig132 mentioned, then they notified me of the path I have to take, which is get an emissions test, noise test and brake test by an engineer. They have provided me with the necessary forms for this. Then I need to get Regency to verify the engine number and then it's all legal.
vspek, I will put up some pictures soon. It looks really nice, the paint is kinda dark grey with almost a purple tint in the shadows, but then a really popping bright silver in the light. I got the paint through Murray Bridge Paint and Decorator Centre, I just used acrylic lacquer and I did it all myself. I actually painted the car five times, trying out different shades of grey before I settled on the one I have now (yes I am completely pedantic and obsessive about my cars).
Thanks all.
Thanks all.
awsome, thanks! lookin forward to the pics :D
Here's some pictures :down:
The first few are how I bought the car, then there's a couple of the boot which I welded up the spoiler holes and show the guide coat etc. Then some of the M-Spec kit being done, then a photo of the car with the M-Spec kit on one with flash and one without flash (unpolished from painting). At this point in time I decided to fit a bodykit and bigger rims, so I rolled the guards and bought and painted an Origin kit. Then there's a couple of photo's of the car as it is in my shed now, just starting to polish it after paint so it will have a good gloss in a few weeks. Couple of photo's of the wheels/brakes too.
Sorry about the poor photo quality though, I'm no photographer and half of them are off my phone and the car is dusty as anything.
Thanks Damien, I'll file that information away.
I have it booked in to get the windows tinted tomorrow, then installed on the 18th of April. Engineering tests will take place the following week if I can get the time off work to take it down, then installation of the E-Boost and a brief check over by someone to verify everything has been done correctly.....then I'll drive it for two weeks to actually experience the car I've been building for over a year and a half, then it's up for sale.
So if all goes according to plan it will be on the market around the beginning of May. I'll include a full list of what's actually been done to it when the for sale thread is started. There's a fair bit I haven't mentioned such as the sound system details, custom fibreglass pods for the tweeters painted same as the car, etc etc.
Thank you all for your input.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
