hi all, just had my motor rebuilt, all the usual stuff forged bottom end tommie cams port polished and flowed head by jhh, gt3076r with rear .82r housing all supporting gear, pfc 660cc injectors greddy plennum hks low mount manifold 044 fuel pump ect nothing missed, but when tuning the car would only push 412rwhp at 20psi heaps of psi left in it but did not push for more as the timing was a problem, at idle the cas was all the way to the right to get the 15deg at idle which the tuner thought cames where out but had aquick look and found that they matched up on top dead center marks, also the car had to have a high idel cause at lower rpm the was a miss but under throddle the miss was not there. oh and im running a water methanol kit if that changes any thing. what could be the reason for the cas to be so far retarded and the slight miss im assuming could be diry injectors? :)
Some timing lights appear to double the reading when setting idle timing.
Safest method is to insert a spark plug lead between #1 coil and #1 spark plug, then set timing "old school".
hi all, just had my motor rebuilt, all the usual stuff forged bottom end tommie cams port polished and flowed head by jhh, gt3076r with rear .82r housing all supporting gear, pfc 660cc injectors greddy plennum hks low mount manifold 044 fuel pump ect nothing missed, but when tuning the car would only push 412rwhp at 20psi heaps of psi left in it but did not push for more as the timing was a problem, at idle the cas was all the way to the right to get the 15deg at idle which the tuner thought cames where out but had aquick look and found that they matched up on top dead center marks, also the car had to have a high idel cause at lower rpm the was a miss but under throddle the miss was not there. oh and im running a water methanol kit if that changes any thing. what could be the reason for the cas to be so far retarded and the slight miss im assuming could be diry injectors? :(
best bet is to pull a spark plug and fit a conventional lead from plug into end of coil-pack and read the timing directly off the lead, i have had a few cars misread (too much noise) from the rear timing loop..... its not common but i need to do it once or twice a month as the indicated timing is too far off centre to be correct..
    • Good to see your rotors appear as rusty as mine šŸ¤Ŗ
    • Took it for a drive to do some logs, Iā€™m pretty sure my voltage issues and electrical noise issues are gone, Iā€™ve sent a log to Adam and am waiting to hear back with confirmationĀ  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4 Ā  idle video from that day just becauseĀ
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!) Ā  Ā  I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding). Ā  I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springsĀ  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
Ɨ
Ɨ
