I was at the wreckers, the VN commodore is a nearly perfect fit.
Call Randy at NISSCO in Bayswater and ask what he put into the ' moster red dr30 that vincent had' i think it was some sort of falcon or commodore.
If youre after an alloy one, look at the S13 range for the SR20 or CA18det. the inlets/outlets are in defferent locations, im not 100% familiar with what goes on with th FJ but the radiators are CHEAP from tawian, like less than $200 landed, off the ebay...
there are real pricey ones, and also cheapi ones...
but the fitment is near spot on too.
I have a 3 core copper Australian spec MR30 item,has inbult auto radiator cooler bult into the bottom tank. it does need a bit of a repair (stone chips in the top section of the honeycomb)
Its only worth as a spare to me for in the future, or sell it for the c0pper!!
Currently installed and running, leaks about 200ml a week.
Dunno how much its worht but fell free to make an offer. Im gatehring funds to get some exhaust mods done (the age old 'over the diff 3 inch' trick)
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5148631
Hey davo, yes everything is all dude.... you speak my langualge@!
another tip for radiator fitment, something I was quite keen to do. theere is a N13 pulsar that is NOT aus made, so the jap version. the radiator is a 3 core copper, the hoses are in the right location for the L series too.
the thing is its width (left to right) is narrower than the stock item, it leaves about 20cm on the passenger side. in this area I wanted to get a sheet of stainless and fill up the gap, but use it for the 2 intercooler pipe holes, and the cold air intake hole.
strap a thermo fan onto the rad to keep temps normal, would do a pretty good job,
i spoke this through with a ralley engineer a few years ago and he says its a great idea as teh cooler piping will be super short.
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5153212
Why would you want a 3" exhaust on your L24E? Even if it's turbo'd it's too big.
Remember quality is better than size when it comes to exhaust and an n/a needs a certain amount of back pressure to work, but an turbo exhaust needs none.
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5154126
another idea that Randy at Nissco suggested was an EL Falcooon aloy rad with thermos - dime a dozen and cheap at the wreckers
on another note (if andrew wanted to know) my chaser is pushing out 220kw at the wheels now :thumbsup: Bit more fun than the old dirty 30 hehe
still keen on a 240z for my next car though
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5157376
I had quotes from pwr to make up a custom ally rad based on my stock dr30 one. I'll most likely
go down this path and post results up later
~$800 later and it would do the same job as any of the ones we have just mentioned unless you plan on drag racing your DR30 and pumping it full of Nitromenthanol fuel and going all twin turbo on it lol
save ya coin for something else and get a second hand/reco radiator
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5159502
:cool:
You can't get cooler than your thermostat tells it to be... if you start having overheating problems, then spend your money on more cooling, until then, give the money to me...
Cheers,
Daewoo
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5159595
I'm getting a custom 3 row alloy radiator made up for the PNV. I don't really care about the cost, as I want the smaller filler neck so I can use the smaller 1.3 caps and I need to have the overflow going to the driver's side so that the intercooler piping can go through the radiator support panel where the overflow bottle is now. With a re vamped 2818cc capacity, I figur the extra cooling capacity wont go to waste.
Cheers, D
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5163466
i got a alloy 2core for a honda civic (yes honda civic lol) in my dr30 coolin a rb20. keeps it under 100deg on the track. was only like 150 or somethin off ebay. in/outlets would b wrong 4 a l series tho
Edited by OUTATIME
https://www.sau.com.au/forums/topic/313339-radiators/#findComment-5163852
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
