hey guys
i know this is sau but im in need of some dire help
ive managed to loose the keys for my motorcycle (honda cbr250r) and i dont know how to remove the ignition barrel.
anybody have any ideas or knowledge on this?
any help would be greatly appreciated!!!
Callum
https://www.sau.com.au/forums/topic/313362-shit/
  • 1 month later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
