  • Replies 186
Thats an easy one, drop it off at Unigroup and let them deal with it :(
Or take it to somewhere like Hypertune and they can do all the measurements and fab work, then off to tune
What power do you want from it? I think ive asked before but its slipped my mind.
Yavuz will say use E85, end of the day its your car. I want every last KW out of it so i have zero regrets once this motor is gone, so thats why i chose it incase that helps your choice?!
I never thought of Hypertune. I might go for a run on Friday morning and see what they can do.
As for power. I'd like to see a solid 400KW at the treads on pump... with E85 well god knows. Yavuz did say when I picked up my car "if you were to put this thing on E85 it would just thrive on it. Be a totally different car" I think that may have something to do with my "highish" compression ratio of 9.0:1.
Cool cool
I wish mine was 9.0:1, i think its something like 8.5:1. New motor is 9.0:1.
What an animal you'll have on E85 and 2 bar!!!
Cool cool
Why so low? Heaps of new cars are between 9.5 and 10:1 with at least a bar of boost... Be adventurous!
I'm looking at true high comp... :(
Steve,
Another GTR to play with.
508AWKW@25psi E85
290 cams, 2.9L Brian Crower stroker.
Ill give you a buzz when we are going for a cruise :D
what snails are run on this monster? is that your engine?
Steve,
508AWKW@25psi E85
Bring it over, there's some neighbors who would love it if it's a single turbo haha
I'll no doubt like it cause it's a 2.9L which is nice and rare!!
How's the lag though, got a dyno sheet?
Unigroup and Yavuz set the standard when it comes to tunes. very impressed with quality and service, going back soon to chase 260kw atw
A1 ++++++++++++++++++++++++++++++++++++
Highly recommended, listen to there advice for proven results
Well said!
there seems to be quite a few people here batting for yavuz, almost like a 'unigroup cult' hehe
After places like CRD, unigroup is a breath of fresh, affordable, friendly air.
I'm a Yavuz groupie for sure.
Full boost by 5400 and revved to 9000.
He wants to rev to 10,500 so is considering a RIPS billet mains girdle :D
External oil pump/Wet sump
PPG Dogbox with a Jim Berry single plate!!!!!!!!!
The thing is epic!
The thing is epic!
Is that a 5 or 6 speed Dave? 10.5 K..... Would love to hear the thing!! RAHHHHHHHHHH!!!!
Edited by Piggaz
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
