Stagea M35 Gallery
this makes me wanna take the rear badges off.
does anyone know if there are holes behind the nissan badge?
There are not, it is just that double sided tape/glue stuff that holds them on.
By the way, did you notice the "TEPS inside" stocker on the rear window of that CE28 equipped M35 above?
If you wanna see what they do with M35's, click on my sig.
Since this is the 5th M35 I have seen with this sticker akes you wonder why they didn't want to do the intakes when they had the chance, aye Craig?
Thanks! Just spent 2 hours trying to find some online... anyone know where I could source these from?
Chris.
You may be searching and waiting for some time Chris.
The Dayz M35 only ran in the series 1 model and was very, very limited at that.
Perhaps if you are after something similar, you could go after a Kenstyle PM35 half rear bumper
If you are having trouble finding it, shoot either Import Monster or Jesse Streeter an email with the link to the page requesting a price.
I am sure they would both be more than willing to help.
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
