Stagea M35 Gallery
Stay silver.
Blacked out headlights wouldn't look right with that blue IMO
Nup, you can buy it from Nismo and put in the R32 air ducts yourself.
I've never seen any nismo kit on IM...
Do I need Jesse to contact them directly?
Pretty sure you can get the front bar on Nengun, or at least you used to be able to.
yeh found it. i think i'de go Carbon.
lets wait and see if someone gets around to doing bonnets first. would really like to be able to put my engine cover back on mainly!
Jesse, IM, RHD Japan (used to have it listed on their website), Nengun.
They will just contact Nismo to place the order.
There have been quite a few go through Yahoo Auctions as well.
What's the approx price they go for?
Must have been difficult to find with the link in the post and all :P
Why can't you get your engine cover on?
Don't say because of the spacer as I know the cover fits with those 19mm spacers.
I thought carbon fiber was illegal under ADR, unless it comes on the car from factory.. I probs wouldnt wanna run the risk of such a blatent defect
well cam it doesnt lol.
ive already made a mess of the "front midship" bonnet protector and all.
maybe you should try fit my cover for me :P it doesnt fit man!
Dunc - wouldnt bother be coz i'de keep the stock one and then go get it cleared...if i was to be defected.. any case dont really know if its worth it. our stock ones are pretty frickin light.
As for the vents in the front bar you will have to use R33 vents... I did them recently - be prepared to cut some serious reo though
Aaron, Yeah I have 350Z brembos on mine, the Enkei wheels have loads of room for any brake upgrade.
Edited by bbenny
The defect is just an unnecessary spend of $135 over sfa gain (going Carbon over FRP). The venting, apparently, drops engine temps by 10'C; so if you were doing any track work it might be handy
So buy one.
They are readily available.
Would you prefer CARBON or FRP?
is that a nm35 bonnet
when i go to the masa sorts website and go to the m tune for the nm35 , when the list of parts comes up with pat number price etc you cant actually click on them to see what the are grrr
WTF dude? We know its not a masasports one...Its Nismo!
are you talking about the front bar or bonnet , so you reckon thats a nismo bonnet then ?
im talking about the bonnet
if so please post a link to that bonnet on a nismo site .......
Edited by Sidius
i experienced the same frustration.
i dont know if the RHD is the same..
I was talking about the front bar.
If you were talking about the bonnet why did you quote me talking about the bar?
*facepalms* nevermind dude...
:closedeyes:
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
