Stagea M35 Gallery
This is f**king hot...
I guess that front bar's pretty rare?
that is hot but is not a masasports one might be custom
WTF dude? We know its not a masasports one...Its Nismo!
are you talking about the front bar or bonnet , so you reckon thats a nismo bonnet then ?
im talking about the bonnet
if so please post a link to that bonnet on a nismo site .......
At no point did you mention the bonnet when you were lamenting about how hot it looks, Dust.
So again, just to summarise for yourself (As everyone else is alreayd on the same page)
Front bar = Nismo
Bonnet = Masasports
Bonnet = Masasports
Bonnet MAY be the now defunct Dolphin item.
I have emailed RHD for a clear picture of the NM35 and PM35 Masa bonnet and will post here if I receive said pic.
I assumed the Masa image on RHD was a stock image; they say they stock bonnets for a bunch of models - so I figured the venting pattern may well be different for the Stag compared ot the image.
Now that you mention Dolphin, I do recall seeing one on their site - but yeah, that was discontinued yeaaaaaars ago :(
Yep same, which is why I requested a picture of the NM and PM bonnets.
The rims are 19x8.5 +22 Enkie GTC01
But thats too skinny, I ordered them online before anyone had done any real experimenting and wanted to be safe. We have worked out with my brothers M35 that 9.5 +35/30 is the ideal fitment - no scrubbing and no rolling necessary.
Although if I were to do it all again I would probably to a little flair/roll and run 9.5 +22
Its only the fronts that are an issue, you can easily fit 11" on the back! haha
What rubber did you end up getting?
I'm ordering wheels, same specs as yours (different brand). Thinking a 235/40-19 would fit the best. Thoughts?
All Clean with new rubber.
Should I do the black headlights? I cant decide if I should keep them silver because the car is dark, or black them out to make it mean...
That is a very VERY nice looking M35. Nice work!
yeah 225 and 245 are more common. I remember the Tyre guy telling me that the only car they can think of with 235 was the M3 so there arent any cheap options.
245 looks a bit big on 8.5J
Here is another pic of the tyre and fitment.
Front bar = Nismo
Bonnet = Masasports
ye but bonnet = masasport isnt on there website they just have the twin vented bonnet
the blue stag seems to be a rare colour compared to all the other colours they come in
mine is identicle colour and body style as this but with a nice wing and nsimo wedin i think its called exhaust
also undecided to black the headlights out
as the black loks awsome on the stagea expecially on the silver or white cars
yet with the blue colour im not sure as you need oposing colours light and dark so darker car means maybe keep silver lights to macth grill , still not sure
Cam - you are correct. Bonnet is a very rare Freeway - Dolphin item. If anyone finds one - i'll take it!!
http://www.freeway-dolphin.co.jp/aeroform/stagea/nissan_stagea_m35st.htm
Scroll down and there is a small picture of it.
As above. Bonnet is Dolphin...
Ive watched YAJ for over a year now; havent seen one come up yet.. and I'll be bidding on it rather than palming it off sorry mate :P
Presuming this thread is simply a gallery of M35's
Was sent these by a friend in Japan.
SLAMMED!!!!! >_<
how are these guys running different widths?
I thought everything goes to shit for the 4wd.
What makes you think that its an NM35? Doesn't look like the guy was really after performance over stance!
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
