I've never seen any nismo kit on IM...
Do I need Jesse to contact them directly?
Jesse, IM, RHD Japan (used to have it listed on their website), Nengun.
They will just contact Nismo to place the order.
There have been quite a few go through Yahoo Auctions as well.
yeh found it. i think i'de go Carbon.
lets wait and see if someone gets around to doing bonnets first. would really like to be able to put my engine cover back on mainly!
Must have been difficult to find with the link in the post and all :P
Why can't you get your engine cover on?
Don't say because of the spacer as I know the cover fits with those 19mm spacers.
I thought carbon fiber was illegal under ADR, unless it comes on the car from factory.. I probs wouldnt wanna run the risk of such a blatent defect
well cam it doesnt lol.
ive already made a mess of the "front midship" bonnet protector and all.
maybe you should try fit my cover for me :P it doesnt fit man!
Dunc - wouldnt bother be coz i'de keep the stock one and then go get it cleared...if i was to be defected.. any case dont really know if its worth it. our stock ones are pretty frickin light.
As for the vents in the front bar you will have to use R33 vents... I did them recently - be prepared to cut some serious reo though
Aaron, Yeah I have 350Z brembos on mine, the Enkei wheels have loads of room for any brake upgrade.
Edited by bbenny
The defect is just an unnecessary spend of $135 over sfa gain (going Carbon over FRP). The venting, apparently, drops engine temps by 10'C; so if you were doing any track work it might be handy
So buy one.
They are readily available.
Would you prefer CARBON or FRP?
is that a nm35 bonnet
when i go to the masa sorts website and go to the m tune for the nm35 , when the list of parts comes up with pat number price etc you cant actually click on them to see what the are grrr
WTF dude? We know its not a masasports one...Its Nismo!
are you talking about the front bar or bonnet , so you reckon thats a nismo bonnet then ?
im talking about the bonnet
if so please post a link to that bonnet on a nismo site .......
Edited by Sidius
i experienced the same frustration.
i dont know if the RHD is the same..
I was talking about the front bar.
If you were talking about the bonnet why did you quote me talking about the bar?
*facepalms* nevermind dude...
:closedeyes:
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
    • Front seats now in, fixing a little rust then front doors sealed up again finished. had to install a fire extinguisher within arms distance of drivers seat for hill climb regulations. little bit of good old silo diff action lol IMG_9146.mov
