95 series 1 1/2 R33 complete interior parts no front or rear seats already sold.
R33 rear cradle no diff and breaks
R33 powersteering rack & hubs
R33 Bonnet
R33 series 2 Boot with Wing, rear bar & rear lights
R33 series 1 headlights excellent condition
S15 front 5 stud hubs with breaks off non turbo s15
R33 rear 5 stud hubs no breaks
Series 2 drivers seat no rips or tears
ALL MUST GO PM OR CALL FOR what u need and for PRICE OR MAKE OFFER
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/
R33 Bonnet
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151072
is that the bit thats rapped around the indicater stalk
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :banana:.. thanx
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151119
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :thumbsup: .. thanx
is it the one where the fuse box is if so i sold it
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151786
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
