95 series 1 1/2 R33 complete interior parts no front or rear seats already sold.
R33 rear cradle no diff and breaks
R33 powersteering rack & hubs
R33 Bonnet
R33 series 2 Boot with Wing, rear bar & rear lights
R33 series 1 headlights excellent condition
S15 front 5 stud hubs with breaks off non turbo s15
R33 rear 5 stud hubs no breaks
Series 2 drivers seat no rips or tears
ALL MUST GO PM OR CALL FOR what u need and for PRICE OR MAKE OFFER
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/
R33 Bonnet
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151072
is that the bit thats rapped around the indicater stalk
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :banana:.. thanx
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151119
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :thumbsup: .. thanx
is it the one where the fuse box is if so i sold it
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151786
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
