95 series 1 1/2 R33 complete interior parts no front or rear seats already sold.
R33 rear cradle no diff and breaks
R33 powersteering rack & hubs
R33 Bonnet
R33 series 2 Boot with Wing, rear bar & rear lights
R33 series 1 headlights excellent condition
S15 front 5 stud hubs with breaks off non turbo s15
R33 rear 5 stud hubs no breaks
Series 2 drivers seat no rips or tears
ALL MUST GO PM OR CALL FOR what u need and for PRICE OR MAKE OFFER
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/
R33 Bonnet
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151072
is that the bit thats rapped around the indicater stalk
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :banana:.. thanx
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151119
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :thumbsup: .. thanx
is it the one where the fuse box is if so i sold it
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151786
