95 series 1 1/2 R33 complete interior parts no front or rear seats already sold.
R33 rear cradle no diff and breaks
R33 powersteering rack & hubs
R33 Bonnet
R33 series 2 Boot with Wing, rear bar & rear lights
R33 series 1 headlights excellent condition
S15 front 5 stud hubs with breaks off non turbo s15
R33 rear 5 stud hubs no breaks
Series 2 drivers seat no rips or tears
ALL MUST GO PM OR CALL FOR what u need and for PRICE OR MAKE OFFER
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/
R33 Bonnet
0433329781
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151072
is that the bit thats rapped around the indicater stalk
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :banana:.. thanx
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151119
its under that, its also is were the bonnet opening handle is, its a long colum, also there is a part there were you can move your steering wheel up and down. about 120cm, just guessing the length, but would be close.. ill find a pic if it helps a bit. im after one with no broken parts :thumbsup: .. thanx
is it the one where the fuse box is if so i sold it
https://www.sau.com.au/forums/topic/313454-wrecking-r33/#findComment-5151786
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
