I still have the following parts for an R32 GTSt and it must go!
Front guards (RH & LH sides, white paint) good cond. $460 now $100 each
L/H Front Guard *SOLD*
Front blinkers (RH & LH sides) ok cond. $230 now $50 each
L/H side Front Blinker *SOLD*
R32 GT-R sideskirt (L/H side only) full nismo three peice set $140
R32 GT-R stock cam gears $100 for the lot
I will further parts available very soon i.e. stock turbos, injectors, fuel pump etc...
P.S. Will soon have digital pictures available for the above just be patient, thanks.
https://www.sau.com.au/forums/topic/31350-r32-gts-t-gt-r-parts/
interested in front guards, front bumper if in good cond. rear lights too.
pics would be great let me know what else you got coz i might be after a few spares.
pm me with pics and whatever else you are selling that you havnt mentioned
cheers
Like to chek out those indicators.
are they the clear ones or are they all orange?
Hi, I will be posting pictures of all the things I'm selling this Monday. Unfortunately I do not have clear indicators only organge ones but are in very good cond.
SinisterR32, I only have the front guards available as the front bumper I had broke.
Thanks AS.
Ok I have some pictures available now and will have some more pics to come throughout the week.
Thanks AS.
PS. Could everyone please read the thread carefully as I am not selling GT-R front guards nor an R32 GT-R bonnet but GTS-T front guards. I do appologise for any inconvenience taken.
Cheers AS.
Pics of GTS-T guards now available.
  • 4 months later...
Hey Ants,
How are you going mate? If you still have the front guards for an R32 GTS-T I'll take them both.
You can call/SMS me on 0413 980 100, email me at [email protected] if that's cool.
Thanks for your time,
Scott King.
Hi Ants,
Might be interested in the blinkers as well, are they the headlight blinkers of the guard blinkers?
Thanks again.
Hey Ants,
Scott King.
Yes I still have all the above items for sale at same price.
I have PM you.
Hi Ants,
Thanks again.
Just for the record..
anyone who is interested in purchasing these guards.
I have the same ones in gunmetal grey.
however my skyline is white, so if the buyer doesnt own a white 32
and is going to get the guards resprayed, please let me know
as i would be interested in a swap
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
