Must sell as i need to get back into a 4door car
1993 R32 GTS-T Black
Just hitting 99,000kms. Car has been meticulously maintained and looked after. Body is ding and dent free its never parked next to other cars. Interior is immaculate, no peeling steering wheel etc.
Motul 8100 engine oil - every 5000 + genuine nissan oil filter.
Motul 90pa - After every track or 10,000
Royal Purple - Gearbox every 15,000
NGK Plugs every 10,000 to 15,000
Car has never been boosted, it has been built for reliability and handling rather than uber power. It will go lap after lap after lap at the track/drift whatever you want to do. It even works damn well as a daily driver. This car can be setup to do whatever you want, drift or track then drive right back to the metro sydney with no problems.
second owner in Aus, was a auction grade 4.5. Unfortunately my job requires me to have a 4 door and there is not enough room at home and it has to go - to a good home only! Sorry no splitting and pillaging for parts. This is an awesome car and deserves a good home!
Outside
GTR front bar
Phillips HID KIT
GTR rear wing
Inside
Pivot Digital OIL/Water temp with fan control
Blitz Dual SBC controller - limits set at .98bar
Greddy Exhaust Gas Temperature gauge
Handling
GAB strut bars front and rear
standard gtst wheels
KAAZ 2way LSD
Tomei HICAS Lock
Whiteline Adjustable Sways
Cusco front upper arms
Adjustable castor rods
Apexi N1 Coilovers- Height Adjust + Compression adjust
Urethane rear subframe bushings.
HKS Pillowball mounts for the rear
Engine
HKS Pod
HKS Dump Pipe
Apexi N1 Front pipe
Kakimoto Catback
HKS GTR 32 Remote oil Cooler - Keeps the engine oil stable around 85 and changing oil filters has never been so much fun!
GTR33 Fuel Pump
400hp Clutch Disc - super easy to drive.
Odyssey battery
Price: $11,000[/b][/i]
Please PM for more information or contact information.
https://www.sau.com.au/forums/topic/313510-eoi-r32-gtst-black-93/
  • Replies 57
  • 1 month later...
still for sale, been sooo busy with work its not funny
i did manage to get some pics of her however didnt get to wash her before hand so she looks quite dusty in the pics
price drop down to $7.5k plans have changed and need this to move as im looking at buying a house.
rego runs out next week however ill give it 6months rego if sold before then.
pics
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
