trying to sell my turbo 240k 4 door for $4500 with out much luck
its hard to find a good one as it is but this is a good one with little rust very straight just needs new paint as it is faded and interior needs carpet and the dash needs to be renewed fixed.
The engine has been rebuilt it has fuel injection turbo and front mount intercooler
ran 130kw on the dyno can do more just needs better computer
the engine bay was just painted and lots of new stuff put back in
has a 5 speed box short shift and new clutch
$4000 worth of receipt
i have only had some wanker in the UK and someone in kuwait interested so far.
Am i asking to much for a car you very rarely see for sale and can actually drive home
Or is there no interest in buying these cars at all ?
Can someone tell me a good place to advertise it?
https://www.sau.com.au/forums/topic/313511-trying-to-sell-my-240k-c110/
L24 new pistons rings bearings fully balanced L24 decomp head with mild cam L20 injection L24 computer VL turbo injectors 130kw on 10psi 3 litre supra intercooler vortec rising rate fuel pressure regulator bosh fuel pump hope these pics are better and i will try car sales cheers Bryan
Wow thats a ripper!
Put it on Carsales, its a quick seller.
Can you give us details on the engine setup? The pics are TINY aswell, can hardly see!
If they are standard VL injectors, they will run out of 'puff', I did run VL injectors on my Turbo L24 (15 psi), and they couldn't flow enough fuel, so now I run 440cc RB26 DETT injectors, they work a charm.
Nigel
Nigel
it runs VL turbo injectors ,tuneability with stock computer is a worry
power fc needs a crank angle sensor of some desription, like a turbo dissy or a big chopper wheel on the crank. or even a missing tooth on the flywheel
VL turbo injectors would run this no-probs, they are like 260 cc or so(give or take)
stock ecu can be tricked to a certain extent, if it works then keep it! dont fix what aint broke!
looks like a nice setup... makes me want to get up and do more on mine now.
Here are some higher resolution pics.
It seems to be put together with a good mix of parts, im actually impressed with the power figure for it too.
If I was loaded, or had a few spare grands, it would be a great daily driver while the R30 gets its makeover for the skylien nationals!
If this is still in S.A. in September it shoudl come join us methinks
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
