Searching around but has been unsuccessful. In fact ive searched via google etc also elsewhere but no luck.
Any threads someone could point out for a guide to changing coilpacks?
Thought id give this a go, its annoying having to pay through the nose for what so many have suggested is a fairly simple job. Unfortunately my knowledge is limited.... clearly.
Any help or point in the right direction would be appreciated.
Cheers,
Matt
https://www.sau.com.au/forums/topic/313534-guide-to-install-coilpacks/
http://www.skylinesaustralia.com/forums/RB...ark-t42819.html
do the above. when u take the coils out u will see that there all attached to 2 metal brackets. take them off the brackets and replace with new ones. easy.
and never again give ur car to a mechanic to change spark plugs or oil its easy and there are tutorials all over that will help and if u get stuck many ppl on sau will be willing to help so just ask
give ur self 2-3hr max because this is ur first time
totally agree with this. these forums are amazing, i changed my oil for the first time 2 days ago, no problems, following these instructions:
http://www.skylinesaustralia.com/forums/Sk...ngi-t10035.html
only a tiny bit different for the r34, couple of screws, and all was fine :P
these are good instructions for coil packs
http://www.skylinesaustralia.com/forums/Di...tml&hl=coil
step 5 is the most important.
for spark plugs, follow the one above, then just unscrew the plugs below the coil packs
http://www.skylinesaustralia.com/forums/R3...ug-t122284.html
important notes for the plugs: you'll need to have the right size socket for the plugs, its different to a camry (learned that the hard way) and be careful with screws if the engine is hot, its easy to mess them up.
and know what to use:
http://www.skylinesaustralia.com/forums/Sp...gs-t104405.html
its always worth having a look through the reference guides in the forum stickys, and the facts/DIY forum
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
http://www.skylinesaustralia.com/forums/Tu...IY-FAQ-f57.html
have fun, let us know how it goes
dunno if its mentioned in those but to remove the coil pack loom from the coilpacks i usually put a flat head screwdriver in the gap at the top, push the tab and twist the screwdriver to lever them apart gently. last thing you want to do is break an expensive coil pack loom from pulling too hard on the plugs
Thanks for all the input lads. Successful effort today took me an hour or so. Spot on there nismoid. Bloody good feeling sorting this out myself. completely sorted out the stutter... Rocker gaskets and brake pads next haha :O) got some searching the forum to do tonight.
I've had a z32 ecu and nistune installed, I'm interested in acquiring the software if possible, hoping to learn a bit about the tuning process. I'm not 100% happy and believe a better result could be had ironing out the tune in normal driving conditions. Early days but it would interesting to have someone drive around and atleast be able to view what's happening with the maps in a live state??
Anyhow, thanks again for the replys gents
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
