r32 gts-t, thermostat housing and hose to rad are stayin cold and it seems the thermostat isnt openin,
car hasnt been runnin for about 3 months but flushed the whole system and replaced thermostat but hose still stayin cold.
could it be a water pump problem or is there an air bleed of some sort near the thermostat housing?
https://www.sau.com.au/forums/topic/313556-cooling-problems-gawddammit/
u need the open the bleed bolt on the intake manifold....
how long do u run it for when ur testing? becoz itl take a good 10mins to heat up to operating temp if its sitting there, maybe 5 mins under road conditions.
alright il have a look for the bleed bolt,
but yeh been runnin for a good 10 to 15 mins each time, just not openin and the temp sensor is readin off the top rad hose so doesnt show the temp inside the head
If the engine is basically idling, then it isn't doing any work. And if it isn't doing any work, it won't produce any heat.
If you can, you need to take it for a drive for about 10 minutes to bring the engine up to operating temperature.
i agree. it takes ages for an engine to come up to temp just by idling. if the car isn't registered then just do laps in and out of the garage. it will still take a while to warm up, but quicker than just idling
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
