  • 1 month later...
would it be better to re pack the clutch packs or buy an aftermarket 2 way like a kaaz?
i got quoted (roughly) $300ish for the clutch packs and $250 for install as they wont let customers install it themselves
intended use is for drifting, so im curious if this re packing is able to hold up to the abuse or will it start to open wheel after a while
coz if thats the case a kaaz is cheap enough these days to buy brand new
I know someone who tried a stock R32 GTR diff in a drift car and it open wheeled at the worst times. They don't have a very agressive ramp angle which means it doesn't lock that much under acceleration. I've always wondered how a stock GTR diff would go if U ground the angled bit that the pin pushes against to a more aggresive 'wedge'. I dunno wat either are called lol.
  • 1 month later...
ive driven on shimmed vicous r200s before...they were terrible and singe spin half way through the day!
Clearly it wasn't done right :D
Racepace re-shimmed & plated my diff, almost to Nismo spec (slightly different i was told)... was what 6 years ago now.
I've done maybe 40 passes @ the drags on it, as well as a lot of serious curry in general use with the 255 RE001s i have.
After 10,000-15,000km's it's still exactly as tight same as it was the day i picked it up, turns both wheels without fail every time :D
R31Nismoid: hey mate... do you think they are as strong/effective/etc as a proper 2 way though?
the repacks i drove were following instructions off this site
http://www.skylinesaustralia.com/forums/Di...Gt-t164288.html
this wasnt repacked like nismo plates but the 2 outer shims making it virtually a locker
now gtr repacking/reshimming maybe different and thus making it more effective than doing it to the other r200s
Well a HR31 long nose is a 2-way mech locker, just really weak.
So from my experience with the HR31 R200, yes they are just as good.
R31Nismoid: ah i see... the r32 diffs are mechanical lsds also from my understanding (correct me if im wrong) so repacking the shims may work
the experiences i have had with reshims came from viscous lsds so there would be a difference i think
but good to know it may be effective to repack the shims!
  • 3 months later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
