  • 1 month later...
would it be better to re pack the clutch packs or buy an aftermarket 2 way like a kaaz?
i got quoted (roughly) $300ish for the clutch packs and $250 for install as they wont let customers install it themselves
intended use is for drifting, so im curious if this re packing is able to hold up to the abuse or will it start to open wheel after a while
coz if thats the case a kaaz is cheap enough these days to buy brand new
I know someone who tried a stock R32 GTR diff in a drift car and it open wheeled at the worst times. They don't have a very agressive ramp angle which means it doesn't lock that much under acceleration. I've always wondered how a stock GTR diff would go if U ground the angled bit that the pin pushes against to a more aggresive 'wedge'. I dunno wat either are called lol.
  • 1 month later...
ive driven on shimmed vicous r200s before...they were terrible and singe spin half way through the day!
Clearly it wasn't done right :D
Racepace re-shimmed & plated my diff, almost to Nismo spec (slightly different i was told)... was what 6 years ago now.
I've done maybe 40 passes @ the drags on it, as well as a lot of serious curry in general use with the 255 RE001s i have.
After 10,000-15,000km's it's still exactly as tight same as it was the day i picked it up, turns both wheels without fail every time :D
R31Nismoid: hey mate... do you think they are as strong/effective/etc as a proper 2 way though?
the repacks i drove were following instructions off this site
http://www.skylinesaustralia.com/forums/Di...Gt-t164288.html
this wasnt repacked like nismo plates but the 2 outer shims making it virtually a locker
now gtr repacking/reshimming maybe different and thus making it more effective than doing it to the other r200s
Well a HR31 long nose is a 2-way mech locker, just really weak.
So from my experience with the HR31 R200, yes they are just as good.
R31Nismoid: ah i see... the r32 diffs are mechanical lsds also from my understanding (correct me if im wrong) so repacking the shims may work
the experiences i have had with reshims came from viscous lsds so there would be a difference i think
but good to know it may be effective to repack the shims!
  • 3 months later...
