hey guys had my r33 serviced not too long ago and its due to be done again, theres a few things that need to be done--
driver belts cracking
coolant flush
power steering pump leaking, replace?
rocker cover gaskets leaking
-option aparently no needed to be done straight away---
gearbox mount has minor cracking
front bumper rubbing on intercooler pipe
so my questions is any of this a major problem and how much roughly am i looking at having to spend?
i would prefer to get all this fixed as im looking to sell as soon as its all ship shape.
cheers for any help :P
https://www.sau.com.au/forums/topic/313585-service/
None of it is a major problem. Here's the result of each:
Drive belts - eventually snap and you'll lose power steering, air con, accessories etc.
Coolant not flushed - radiator and cooling pipes become clogged with rust and scale, coolant loses its cooling/anti-freeze properties.
Power steering pump leaking - will shit you up the wall and you'll be replacing fluid frequently, other than that just noisy turning when running low and impossible to steer when empty.
Rocker cover leak - oil all over the engine bay, if it's a minor leak it's not a problem.
Gearbox mount - will vibrate the gearstick/gearbox.
Front bumper rubbing on intercooler pipe - just aesthetic damage over time.
So that said, none of it is really a major problem in the short term, but things you should attend to when you can.
https://www.sau.com.au/forums/topic/313585-service/#findComment-5150349
hey man thanks heaps for your help, pretty relived that none of these problems are major. again thanks heaps :)
https://www.sau.com.au/forums/topic/313585-service/#findComment-5152664
