1993 r32 registered rb20det turbo , complied , registered , regency passed all the money spent to pass regency!!! hamburger with the lot lol
Imported from melbourne last year , regency defect after 2 days
over $4,000 spent on new suspension components , bushes , seals ect!! no leaks , no squeaks , no police hassels!!!
exterior...
Grey 2d coupe , rear spoiler has been removed and boot welded professionally , gtr rear pods , side skirts,., front bar gts-t with open mouth and faced edges looks like a bomex bar but better !!!! car has been resprayed recently , really good condition paint ,,, and then i reversed rear quater?(cracked bar and small dent) into something the next week!!! fat bad luck but will be fixed at my expense when i get the chance really busy with work!!!!
"""""Gold brand spankign new 100% tread work te37 18/235 they look awesome!!! these are worth 1750$$ on their own , i took off the stickers thinking they looked shit now i find out work is a good brand lol!!!!
Interior''
Nardi Torino steering wheel , little bit of flake but hey full drift spec.. short shift kit removed atm due to not wanting police attention comes with car,, boost gauge , good condition seats no rips or burns,, cd played , speakers , 12 inch sub and amp boot,,, small crack in cd surround probably 20$ for the whole surround
Engine""
Just serviced at 151,000 its at 152,500 atm!!!!
always serviced every 6-7000 kz with good oil and good filters
Rb20det twin cam , head has been done at some point has the red rocker covers but is the silver top 20det
*Huge fmic with alloy piping 3inch , looks awesome through the front bar
*3inch full Xforce exhaust , highflow Xforce cat , polished 5inch rocket tip , 3.5inch brass dump off turbo passed regency 91db , but i took of rear muffler i still have it but i estimate around 95 - 100dp now sounds killa,, gotta love rb20 idle bubble lol
*z32 afm with huge pod filter and cold air intake setup
*remapped computer by The speed lab , setup on dyno can map 17 psi but never has
*car also comes with uninstalled Greddy Emanage system with all looms vauled at 600$ brand new!!!!!
*rb25 highflowed turbo ,, can run 18 - 20 pound of boost aparently !!! would be saf at arounf 17 all day everyday
*single stage HDI boost controller i run 11 pound but has been at 1bar boost safely
*bosch 044 pump , 550cc injectors i think morpassi or bosch not sure tho,,,
*tomei adjustable cam gears , havent been adjusted much just a bit on the dyno again
*superspark coilpacks , platinum plugs
*brand new radiator cost $300 , brand new water pump $300
*dyno result ,, when i first got it it has a manual bleed and maxed out coils it was making 205rwkw at 1 bar , fuel pump was at 90%
*now with superspark coilpacks , electronic boot controller , 2 month old fuel pump $399 and boost lines set up to pick up fmic usually has extra lag running lines through carbon canister and not picking up ic pipes ,
!!!!!!!will make over 215rwkw safely at 15 psi !!!!!!!
With the emanage boost can be increased , fuel increased , cams dialled in more aggresively will make 230rwkw at 17.5psi with awesome cam timing!!!!!! and chuck in gtr or tomei cams and youll pull 250 - 280 rwkw
this car owes me huge amounts of money!!! but i will take """"$11.5k with the brand new rims and emanage and the dent fixed!!!
too be honest this car is very quick and has a lot of meaning to me , i need the money as i have 1900$ in legal fees due to some stuped incident!!!
Contact me via pm!!! or message / call me 0434008133
may consider swap for ute valued at under 5 grand + cash adjustement my way
  • 4 weeks later...
