I replaced my cam belt finally and noticed that the old one was one tooth out.
The crank was clockwise one tooth out.
So if I were right that would mean that the valves were opening late and closing late.
Hence maybe more exhaust getting out but less boost getting in?
I have noticed that there is heaps more down low off boost torque but I'm not sure if it goes any harder when on boost.
It also idles really smooth and with the copper 7's I am now able to idle her at 600rpm with out it missing and making the idle drop to 400rpm.
It also starts instantly as soon as you turn the key, before it would turn over for maybe 1-1.5 sec then start.
Even with the cam timing being the way it was before it still made 156rwkw on 12psi of boost with the fuelling perfect up top.
So what do you think ppls should it be slower or faster now?
Just a note I think the head has been off before as I can see marks on the head bolts which would coincide with the cam belt being a tooth out.
:burnout:
https://www.sau.com.au/forums/topic/3136-cam-belt-was-out-one-tooth/
Guest Stocker
It was probably one tooth out deliberately. Retarding the cam gives more power upstairs, and advancing more downstairs. One tooth only is the limit though!
When I replaced my belt, it was REALLY stretched(so a bit retarded), so it made all it's power up high, and would rev to 5800-6000 rpm(stock RB 30), when I advanced the cam one tooth while replacing the belt, I picked up a fair bit of bottom end, and now only revs out to 5250 or so rpm, but that suits me better!
Regards, Andrew.
It did run pretty well apart from the slight rough idle like a pop every now and again that is due to the colder spark plugs but it made the car almost stall if i didn't have the idle at around 800rpm.
Now the car still does actually pop a little on idle but it doesn't make the idle drop to 400rpm. It sits smack on 600rpm.
I noticed that it is pretty easy to knock it out one tooth if you can't see the lines on the belt as you can't really fit your head inbetween the front of the motor and the radiator support to line it up by eye level.
Grab a harmonic balancer puller from your local auto shop for around $18 then buy some M6 High tensile bolts and a couple of strong washers to suit, pull the balancer off then pull off the front covers and have a quick check.
Oh also you will need to pull the belts off which are pretty easy apart from the power steering pump that takes ages to wind out unless you have a ratchet ring spanner (:D
While you are there you may aswell do the waterpump and cam belt tensions ets.. Mine turned out ok I thought the tensioner was buggered but it turned out to be the AC tensioner bearing.
New bearing for that was $5 also :D
  • 1 month later...
Hi guys,
I noticed you mentioned that the cam belt does cause rough idle and the occasional pop?
I just got my skyline from japan, it's low on Ks, about 45+ thousand (I'd bet it's knocked back), other then that it's clean. However, idle is alittle rough when it drops to about 500 or 400. I can hear the sound of the engine rising and falling. It gets alittle worse when I turn on the lights.
Any ideas? I'll have the plugs and fan belt changed soon, I hope it'll help.
That sounds like your AAC Valve that has a solanoid attached to it at the back of your plenium near the firewall.
When you do the plugs make sure you slap the proper plats/iridiums in otherwise when the idle drops you will still get the slight pop.
Do a search on the AAC Valve and how to clean it.. ~$10 to do it your self.
However, the strange thing was when the plugs were pulled out. They looked shiny and new. All that was done was a regap and clean. The idle wasn't completely eradicated (but better) but the engine rise and fall was still there. I dunno if it's due to the car sitting at the docks for too long (corrosion mebbe?)
Zoel i am pretty sure when your cam belt skips teeth it will lower your performance... i had the same problem but didnt know till my mechanic had a look. he told me that i had skipped 4 teeth. as a result i had a huge loss of performance and my exhaust was much much softer...
I think that mine being a tooth out was an accident as i can see from the head bolts that the head has been removed previously.
But it did make 156rwkw on 12psi which isn't to bad i thought when the cam belt was out a tooth.
Especially when its only 1 or so psi more than std boost.
This is way interesting Joel. Cos it relates to playing around with cam timing using adjustable gears, and how much you can get away with before piston finds valve:(
Does anyone know the number of degrees for each tooth?
BTW Croat ... Super Glory Super Glory ... sorry couldn't help it.....
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
