My a/c on my skyline turns on and off, An airicon mechanic said it was and idler problem. It only does this on idle. At times the revs fall though the floor, and sometimes stalls the car. Even @ low revs. It's quite dangerous cus sometimes it stalls the car when im driving along and i change gear, and the dies on me.
I've been playing around with the aac plug and cleaned it.
The problem is intermittant. So it's hard to tell if it is fixed or not until l8r.
Think the AAC could be hald stuffed not sure though.
Where the best place in brisbane to find parts to fix this?
https://www.sau.com.au/forums/topic/31360-idle-with-ac-problem/
I think i know what the problem is.
Today I cleaned out the AAC valve and the part of the plenum where AAC connects to, was gunked up. 2morrow will tell if my cleaneing job was sucesfull.
the AAC valve control the revs when car engine is on load. I think it basicaly sets the revs higher when it is on load, but becuase on load it keeps revs relatively the same.
Well, That's what i've figured out 2day. yesterday I would not have a clue what it done.
went to an Aircon guy 2day, and He siad not 2 bother regassing till u fix the idle problem. It's still has gas, but the aicon guy said to give it a top up.
Well I done a quick clean of the manifold where the AAC calve connects 2. It seams to do it more in the heat. I'll see how it behaves tomorrow.
Thanx Dave, I'll b keeping that in mind.
Heres another possiblity-
Check pin 9 on the ECU. This is the air conditioner idle-up input. When you switch on the air conditioner, it will pull this pin to ground (zero volts). This triggers the idle up sequence that opens the AAC valve to supply a bit of extra power to the engine at idle.
When you switch off the air conditioner, this pin should rise to 12v (open circuit)
I'll check ECU mayb 2morrow. I also looked at my AFM 2day, looked ok. So might have another look at the AAC valve? or what i think is the AAC valve.
I never lubed it up last time, I remebr looking into the manifold bit bolts up 2, actually took it of and cleaned it out. There was a spring in there somewhere 2, think it was on the back of the screw.
How do I change the Idle speed. there's 2 screws that u adjust, one on the back of AAC and Where's the other. Also hear u fine tune the normal idle on the back of the ECU on a pot.
It only likes to stall after it's warmed up and driven around a bit, turned off than on or just after a while in stop start traffic. mainly on very hot days.
I thought that lack of gasses the compressor would actual have an easier job and would most likely try to rev higher because there is not much gas to compresss. Dont know. I'll keep it in mind, since it only stalls @ idle with the A/C on.
  • 1 year later...
Hey wow it's one of my old posts.
Yeah I manage to find the problema and fix it. (It still plays up every now and then but usualy been quite good). One method to get it working when it plays up is to accelerate up in the 5k 6k mark.
anyway...
I changed the AAC unit.. or actually IAA unit (not sure what is what when it comes to the names off it)
which stands for well AAC is something like Auxilary Air Control i think or something like that.
What it does is when the engine is on load at idle it will turn on and componsate adding a bit of revs by changing amount of air feedback. Now what happens when u get bellow a certain Idle point the computer goes Oh crap what's going on were loosing power better turn stuff off and turns off is the a/c.
What actual happens is that one of 2 things happens .. or both.
1. the seal inside the unit actually just wares out and leakes air.
2. the spring becomes compressed and does not rebound back to it's orignal point therefore not responding quick enough to componsate load.
I went to zoom and bought a second hand unit for about $90
now if i remeber it was something like $600+ new from nissan.
Also there are two type of the unit that fitted on the r32. but not sure for the r33.
The unit can be found at the back of the plenum. it has a 2 pin connector with a solinoid. Also as 2 air pipes running into it and should have an Idle adjustment screw. And like a bolt on module to the plenum.
U can take it off and clean it out and usualy the gasket does'nt brake. I've played with 2 now and still have both gaskets ok.
Just a clean out show some improvement on my r32. Alot of carbon builds up inside the unit.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
