what turbo would be best suited for a rb30
What do you want out of it? A 5557 .82 exhaust with the surge port (4 inch inlet, 2.5inch outlet) comp cover would be killer on the street. Billet comp wheel, twin ceramic bb core (that dosn't need water cooling). Super responsive 280-300rwkw
lol man, your opinion is based on stock twins! get a 5557, I dare you :D guinea pig lol
Once we sort the wiring/ignition problem on my guinea pig stock rb25/plain bearing 5557 combo, I'll be able to post the results... not long now.
It would happily be me although I am still in developement stages. Ive got a car and a motor, the two dont match yet.
Will be interesting to see how these 5557 turbos perform against a 3037.
Whats the rest of the setup the 5557/RB25 is going to be using? Manifolding wise etc? Completely unopened engine eh?
Yeah stock 100k rb25. It's currently hanging off a stock manifold with a wastegate adapter and 46mm PT wastegate.
I do have an HKS low mount manifold waiting in the wings if it works out ok.
650cc injectors, nistune, rb20 loom/ecu (in an r32gts-t), port matched greddy copy intake manifold, gtr cooler, n1 oil pimp, vct switch, 4" cat, hks super dragger, splitfires...
Actuall killing the same number coil pack right now.
J.
350wkw on stock manifolds, stock RB25DET, 52trim GT3037/GT3076R with .68a/r turbine housing - I could be wrong but you use a Dynapack as well?? If so, add some kw... not to mention potential gains from using better manifolds etc.
Just looked at Powertunes site, saw they use a DD... crikey. That suggests its a crapload.... very impressive result then. Thought it was a dynapack :devil:
Yeah dude, we nearly fell over! Actually it was a combo of 1) the power it made and 2) the fact the engine internally is bone stock (aside from drop in cams) and is holding together!
Wow thats some crazy results. I was waiting to see the results of the 5557 to see which one i have to buy. Was planning on buying the 5857 with a .82 rear for my RB25, now i'm not so sure what to get hmmmm.
What would you guys recommend? the 5857 with the .82 rear or .63 rear? or the 5557 with .82 or .63 rear for a RB25. My goal is 300kw maybe a bit more. Engine has CP pistons but stock rods, race bearings ect.
Edited by Girorostar
    • Nah, if I need to fit people in a car I'll just use the Mrs car, the MX5 is perfect for what I need as a fun little sports car for fun on the street As for getting in and out of the MX5, I have no issues as I am a short arse who does lots of mobility training 🥷 If anything, I have been looking at Daihatsu Hi-Jets for a work hack, I helped one of my mates move some stuff with one recently that he picked up from Just Jap, it was a little ripper and plenty big enough for what we needed, it would also be super handy for me as I do alot of gardening, and plan on having some veggie patches and native gardens in the place I buy next year when I retire I did alot landscape gardening and growing veggies prior to my current job, and loved it, and that is a hobby that can keep me sane in my retirement, and as such, the little 300kg load capacity would be more than enough for what I need it to move around I have been looking at utes for just this purpose for a while now, and a near new 2024 Hi-Jet can be had for under $30k And I would rather look at a quirky little Hi-Jet than pretty much any other little ute, well, apart from a Brumby, I love the little Brumby, and weirdly have never owned one yet I was going to buy a heap of raffle tickets to try and win the Brumby that MCM built for Subaru Australia, but sadly I totally missed the raffle, I even filled in some form to be told when the raffle started so I could buy tickets, but to my dismay I was never contacted and found out I missed it when I was randomly googling Brumbys last year... #conspiracy  Maybe I should just buy a Brumby for a little "work hack".....LOL I use to be indecisive, but now I'm not sure
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
