OK- was wondering what you'd refer to as Simon has made 410kw on a Dynapack, which read similar to the Dynojets. DD read LOWER than most, doesn't make them more accurate - but it helps to know which scale you are talking on.
Given 700-750whp on a Dyno Dynamics and 800-850hp on a Dynojet/Dynapack (difference isn't really quite THAT much, but for sake of discussion we'll roll with that) mean pretty much the same thing to all of us, thats an epic result from a turbo that size!
The other issue is...if it was on a dynojet/other american dyno...its whether its configured to convert to crank hp, or just read the straight rwhp levels, from memory they can be configured to do either, which is why some results vary so much. I have read stories on some of the yank v8 forums of a car rolling out after a tune on X dyno, going across the street to Y dyno and losing 80odd HP
I try to use DD results, as they are kind of like an industry standard here in aus because there are so many of them.
My mind is open to that...or I wouldnt be telling people that they WILL make over 400rwkws with -5s on a 26.
Didnt Mark Berry make 450awkw on -5? Again the last 50kw is what cost money
700hp I would believe...not 850, Im sure I have said it in this thread to, in that when I see a yank dyno result I pull 100hp off it and it seems to be fairly accurate, So yes 750rwhp is entirely possible from a turbo rated at 720hp, on a engine on good fuel with excellent VE
Quick edit - while im not trying to start a shit fight cause I cbf.
look at the Sierra Sierra EVO, COSWORTH build and tuned motor with a EFR 9179 turbo makes 850awhp.
You cant compare 2 different types of engine let alone 2 of the same engine with varying VE. One which was developed in the late 80's and one that was built after 2005....
nur33's R32 has a HKS T62R (1200hp) and makes similar and that thing has the best of everything
best of everything doesnt mean its right!
I just cant see a 62mm/700hp turbo making that much power, especially with one of the smaller turbine housings fitted.
the 6266 looks to be a brilliant turbo and had these results came out 2 weeks ago i wouldve grabbed on instead of the T78
Unlucky!
One member from supra forums ran 9.9sec in a full weight supra on a factory built auto (6265) 6months ago this new version was always going to do good things..
http://www.supraforums.com/forum/showthread.php?633847-Na-t-6265-new-best-9.99-133&highlight=6265
Here's a heavy as soarer with a power sapping Turbo400 running 9's with a 6265 and 640rwhp
You need to be a member to view.
Ill look for the supra thread later..
Na-t, 6265 new best 9.99@133
Just got home from the drags. Got a few runs in and finally hit a high 9. I previously had a best of 10.1x on a pair of 265/40/18 mt dr's on is350 wheels with a 1.6x time. A good buddy of mine let me borrow his M&H dr's and I was able to cut a little better 60 foot. Just enough to squeak a 9.99 on my last pass during bracket. I was very happy to say the least.
Boost was a solid 30 psi and I launched with around 15psi as anything more would have massive tire spin. I honestly didnt think this little 62mm turbo had a 9 in it, but I am pleased to say it does!
Time slip consists of.
60' 1.527
330' 4.206
1/8 6.428
mph 110.33
1000' 8.357
1/4 9.994
mph 133.61
not sure why the low mph as the car was trapping 137-138 all night? My buddy that was filming went home early so I didnt get any footage of the car running the 9.99. I did however get the in car video with a gopro of that pass. Before he left for the night he had filmed a few 10.0x passes. I am uploading the video's on youtube at the moment, as I finish I will post the link here on this thread.
So.....Differences between the 6266 and the 6265? is the former just an update? price differences and what Split T4 rear housing should I be looking for on a 1JZ? was thinking 1.00a/r?
Or Should I look at a 6262?
The PT6266 has an updated higher flowing turbine wheel, not aware of any other differences.
Here's a dyno plot from an EVO running cams which are on the mild side for this kind of power (probably good part of the reason the power doesn't keep going to higher rpm), 35psi on E85 with more to give with more tuning... which should be done this week.
This is a 2.2 litre with a T4 open turbine housing:
Because of the natural "blargh American dynos are BS" I take the liberty to provide some very conservative calculations to give what it should make - at least, on a Dyno Dynamics at equivalent rpm:
4000 - 125kw
4500 - 225kw
5000 - 363kw
5500 - 412kw
6000 - 535kw
6500 - 555kw
7000 - 561kw
7500 - 555kw
8000 - 528kw
8500 - 509kw
Over 2500rpm with 500+awkw, its pretty insane imho. Look forward to seeing what it does with more boost, even though its beyond what any of us would normally push :)
For what its worth, both of them would be a heap better than the T78 haha. But yeah, with a 7200rpm limit I'd be looking at a PT6262 at most.
How much are you looking at spending? Have you considered a GT3586R-HTA from Forced Performance? They are very very cool turbos...
Hahaha If I had the money I wanted to have I would get something with fancy ball bearings etc...but alas I am poor atm...so spending around the 1200 mark....still considering a BW airwerks but they are even bigger physically than the T78-33d lol
So yeah...6262 with the .84 split rear...had a look at some results on the net, but they are all dissapointing (car setup not turbo + tiny open t3 housings) but even with just a AFC and injectors they are making 400+hp on around 20psi and PULP
which is fine by me...not fantastic but gives me hope that a decent tune will net 400 DD hp on less boost.
If it doesn't I will forever keep rubbishing PT turbos lol
Oh - you are getting a plain bearing PT? OK yeah, if size is an issue then the PT6262 is probably the best value for money turbo thats going to make a good amount of power. Otherwise a BW or a Holset unit would be brilliant.
looking forward to it, as per ryan1200's advise, and Me loving stupid amounts of power I am now confuzzled as to getting the 6262 or 6266
Logic says 6262 for a street 1JZ....only if they can supply a larger housing for it, (the 1.00 a/r twin scroll would be good)
However the a/r ratio means nothing if the .84 precision housing is of a larger frame than say a GT35R?
Anyone know?
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
