Precision Billet Turbos
Why does big boost have such a bad stigma?
Its my understanding that it's not like the "boost" is anything scary in and of itself. Its combustion pressures that blow your engine up, not "boost". Some people think that because person A is running more boost with a turbo than person B with another turbo, yet theyre making the same power on the same engine, that person A more likely to scatter their engine, which is false, no? The byproduct of high boost is more air, and thus fuel, in the engine, plain and simple. Am I wrong with this logic?
You are correct in a sense. But the more you compress air the hotter it gets so leaves less room for error in the event of a slight lean out etc
It also comes from the dark ages of horribly inefficient turbos the just blew hot air at anymore than a hand full of boost.
I always think back to the millions of dollars car manufacturers put into things. Etc why doesn't ford use a tiny little turbo and 40psi instead of a gt35 to make 240 kws etc
Less boost means a more relaxed engine in general. Efficiency is key. I'm sure we would all like a lazy 7psi to make 500hp but the reality is we can so it's always a balance between response and power on our small engines
If the only thing that was different was boost you'd be perfectly correct, the issue is the higher the boost pressure the hotter the intake gas, also the higher the EGTs and hence everything is just generally hotter. Heat is the enemy as it makes detonation easier, so you need to do fancy stuff like very efficient intercoolers, water/meth injection, exotic fuels like alcohol to be able to run this kind of boost whilst still running some margin of error from detonation.
When running this close to the limit you would want to start trimming individual cylinders by using individual EGT probes etc, it starts to get expensive very fast. I doubt many (if any at all) of the guys running 35psi are just simply running an intercooler and 98 octane fuel.
You are correct.
Then it would behoove one to run a cheap simple mod like an BAT (boosted air temperature) sensor in the intake.
Here is a question...where teh hell do you find a 3 5/8" V band for theses thing?
can find 3", 3 1/2", and 4" easy.......3 5/8".....
or do you simply use a 3 1/2" unit?
Powertune have them in stock to go with the precision turbo's.
  • 3 months later...
PJ....that R34 with the stock bottom end and stock cams....what was the power at the hubs? Im presuming the dyno run is showing corrected power at the fly? Im in the UK and I want to run a single on my Forged RB26 in my R32 GTR (Stock head and cams). Im going with a T3/T4 topmount manifold and was looking at the 6262.....I want 500BHP at the hubs at no more than 25PSI.......is this gonna be do-able with the 6262? Im looking for spool compariable to uprated twins but with the ability to crack 500BHp at the wheels. What do you reccomend guys??? Exact turbo specs please?
Oh.......why all the reference to 4 Cylinder Nissan engines and even worse Toyota engines??? Surely you guys must be all running 6 cylinder RB's in the main???? Just find it a little strange as in the UK where im from there isnt a lot of skyline interest in 4 cylinder mills....its all RB26/26/30 etc.......
Cheers
Andy
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
