We have a GTR over here that runs on full 100% ethanol. Makes 630rwhp on a roller, gets the pure ethanol very cheap through a limited source.
Almost wouldn't start after sitting at the track on a cold night so not really a great recommendation haha
E100 isn't new, been there done that :)
An R34 with those K's though, never seen one in real life with that many k's on it!
You still haven't, it was a picture :ph34r: hehe
Its a good sign for the other 34's on the road though, shows they are well built!
Kurtis, the suspense is killing me already!
Oh come come now. You Daniels 34, tuned by Status - makes over 400 on E85 with just a Nismo :)
Exactly my point. 044 around 200lph. Nismo 246lph but i cant find specs for flow at higher psi which is where it counts
Well for a while I've suspected the Nismo pump to not be "as much" of an upgrade over a stock GT-R pump as many would believe.
It's simply the cheaper option so hence everyone goes down that road given a stocker is 10yrs old and offensively priced from Nissan
There are some numbers on a stock GT-R pump below (makes for some interesting reading).
http://www.stealth316.com/2-fuelpumpguide.htm
working in the boot of his car paid off today, AFR's are doing exactly what i wanted tonight. Just got back from a drive with it. went down to the servo to top up the $21 worth of EFLEX, racked up some sensible km's, think we are up to 50km just cruising around with a few squirts on 14psi low boost, and only 1 half throttle tyre fryer on high boost, got scared as midnight and tired, had a big day.
Maxed out at 367kw on 22psi, tried more boost with no gain, but very impressed as its all legal in the way of Catalytic converter and wastegate plumbed in, thing is a sleeper.
still got to finish the tune back from E67 down to 98 octane but atleast everything held together :D
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
