Mate if I was you I would have done it a year ago, I hate my -5s I should have went single from the start. But than I also like not having to worrie about the cops.
What exhuast you gunna run? Or you going to adapt the RPM one?
There is an issue SOMEWHERE in your setup. 330 on 5's is a little below par.
Well the RP one is twin 3 inch all the way. I'm thinking about not running the twin's front pipes, coming out the back of the turbo in a 4 inch then splitting that into a twin 3 inch to meet up with the "catback". Each gate will pluimb into 1 of the 3 inch pipes.
The SR result im reffering two, we overlayed my 2.8 and 5's. This SR with a 6262 had MORE bottom end grunt and made an extra 10 kw up top.
i no man, ill work it out one day, got a new exhuast coming and a new intake setup. So ill try that out, and c how it goes. If nothing improves ill just drive it as it is, till Stevo comes up with the goods on the bits and peaces to make her a lil bigger on the bottom end if you no what i mean, than prob throw the -5s in the bin lol
im very interested to c how this turns out but
Precision turbos are getting a lot of love recently, but with the results they are putting I think it's definently justified.
Is there a reason they aren't as common as Garrett's? Like we're they not to good back in the day or something along those lines?
^ Good question. I've followed US/Euro results for years and bleated on about some of the results people had been getting wth FP and Precision turbos for years and said the Garrett GTX turbos have been too little too late but for a large part seems to have fallen on deaf ears MOSTLY here, got the typical "inflated dyno figures" speels. Understandable that people need to see the results from familiar environments and setups, but that is probably largely why they haven't spread around this part of the world so much. Overseas in the EVO/Supra world they are EVERYWHERE.
Its also alot to do with the parity of the dollar, i have bought a one, yrs ago, and sold it and i bought a innovate turbo yrs ago from the U.S
when they where the "big" thing, but they where crazy money compared to garrets once you changed the dollar over and imported
compared to a garret here.
The other part is people talked out of there absolute arse about them on here without even trying them..with all the inflated dyno and need mega
high boost to work bullshit..its given me a good laugh lately.with the all results coming forth ...lol
cheers
darren
A little? lol... A LOT!
Be interesting to see what you think, going to have the -5s running first for a month and then do back to backs?
Given you are changing head etc ;)
I'm still undecided Ash. It's a lot of work and a lot of dicking around.
Part of me thinks I've gone too big but if a SR is matching my -5 effort then I think I can go up one size, given I have 500 cc over that particular result. If it is too big well I'll drop back to 6262 or 6266.
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
