A little? lol... A LOT!
I just wish I new where to start, it's got everything it needs to make a decent number, but it's knock restricted.
When jez tuned it last the exhuast was way to small, now that I've got a bigger system coming from jap and I made some 3inch tuned length front pipes into a 4inch merge. The exhuast issues should b over, so it's back to jezza's shop to c if there's any gains.
Strange thing is, I had a 4inch system made, and we chucked it on the dyno, only got 7kw gain with adding timing and boost.
C what happens, maybe we need to play with the cams, or something.
Depends what manifold you get.. The Full race one I have was designed for fitment on 33/34s. Tried putting it on my 32 and the compressor fouled on it..apparently full race have rectified this for 32s now
A/C didn't work anyway so I'm not too fussed, then again I may have wanted to fix it one day :s
I saw a dyno graph from a famous 32 on the weekend. It's now running a Precision single (6766 I think he said). The Precision shits allover the -5's for response on the graph, and from his times, on the track too! The 32 is still 2.6 as well so these turbos are obviously a good thing!
Correct! and yes WOW! it has me thinking the EFR's are on their last chance... :yes:
I've already emailed him to find out exactly what version he has on the 32.
The 34 is running one also, however he likes the one on the 32 better.
One thing he did say to me was to buy bigger than I think I'll need and I won't be disappointed, they are that good.
I would choose a Precision over an EFR any day. . .too much hype with the BW's. . .too many results to look away from Precision. . .sorry, but a 2-year wait on an EFR is ridiculous. . .
bri73y.. .do you have a chart for that r32 running the 6766? I'm running this on my FD. . .sounds too good to be true that it would shit on the -5's. . .
No sorry, it's not my car, although it has lived in my garage for a while previously. Damn should've stolen bits off it when I had a chance.... :whistling:
Any email back? The one on the 34 did look a little bigger but by how much I couldn't say. I'd love to know!
What do you think you will order for your car John? 6466?
Hey Joe, or anyone for that matter..
Is there any evidence that the Full Race Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a good manifold and probably a Precision..
wouldn't the one Jez is running, with 30+ psi on a 2.8L with cams etc see 450-500rwkw ? with awesome responce .
Edited by tricstar
Is there any evidence that the Full Manifold is worth the cost vs 6boost & ETM etc being about double the $ ??
Will wait and see how Piggaz's turns out, as I also have a 2.8, been running a TO4Z for a couple of years on stainless china manifold, time to get with the times, with a 6boost and unplumbing the gate.
Fixed, no need for new turbo :)
Well it made 436 on a 2.3 SR with 24-25 lbs of boost on the same dyno as i made 425 with -5's. It beat my setup low end and pipped me up top. I'd love to see what it would make with 30 psi!
If the 6466 is too big just rip it off and drop back 1 size. Little touch up and away we go!
Honestly mate don't know if the full race is better or not. Would need to do some back to back testing which would be a real pain in the ass as you would need to plumb up 2 different sets of gates.
If I had my time again I would probably just bought a 6 boost one for reasons such as
1. Cheaper
2. Quicker to obtain (each fullrace manifold is made On order)
3. If it cracked or failed in anyway would be easier for warranty
4. The full race is a bit of a nightmare plumbing wise.
Though I do like how the manifold looks and how it makes the turbo sit towards the front of the car.
I also had to cut a bit of the re enforcement out of my bonnet to fit the Massive frame of the BW
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
