Being built by advanced and tuned by JEM I doubt anyone will question the numbers.
Interesting about the breather being normal for that power level, not something I expected.
Because u dont normally see it.
Out of site out of mind :)
It's the catch can breather.
For anyone possibly doubting the numbers, it ran 10.7@147mph at WSID with 490rwk. Next time out with 536rwk should do 150mph+
The car is also on the Motive 16 Drag battle DVD.
I'm questioning the numbers! That was 10.2@147 not 10.7! :)
This was the first thing I noticed as well
Seems odd to keep pulling those numbers with that happening
It was mainly in relation to that...
Yeah I wasn't sure if it was 10.7 or 10.2 :D
Edited by SRS13
I might be selling my 5858 BB turbo. Brand new, box hasn't even been opened!! After $1450 for it.
Thinking about going bigger (6262) as the engine being built will need a bigger turbo!
If interested PM me.
Edited by SRS13
Finally got some numbers but its not done yet,
On the New motor, with the 6262 .84 TS BB CEA.
Run-in tune (super safe) verylow/negative timing, 9-10 psi. 210-220 rwkw.
Turbo is super responsive and perky even with the timing so low, I noticed instantly its very throttle responsive, its very possible my intake setup helps in this regard. But the way it moves the air so quickly I have a good feeling this setup will be pretty decent on the 30/25 with vct!
One noticable characteristic.. the turbo seems very loud. even on low boost. however i am moving from lowmount to high mount during this build, so that might be why i think that.
will be doing real tuning next week if all continues well. Will post numbers as promised when its done. Unfortunently still running hte PFC and Tomei Z32 as no one has purchased the gear yet.
-dale
Edited by SilverECR33
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
