Just confirmed my suspicision for the laggy-ness, inspected n tensioned my throttle cable to just about touch-tight responsiveness. Doesnt feel so laggy now anymore, got a lot of the crisp touch- responsiveness of my stock turbo back and smiles all round. Very nice street turbo the 5558, mines not so linear but gives an angry meaty kick at 4000ish which is what I always wanted. Still running pretty pussy boost 16-18psi so top end is left wanting..
Ohhh man ur really peer-pressuring me lolz..:( was thinking water injection, re-route part-cooler pipe, crank up boost as next mod... And clutch when the stocker shits itself haha. Have you seen my dyno-plot, and any comments? Laggy hey.. Well I only know the stocker's response thats why I keep saying its a bit of a lag-boat.
Ohhh man ur really peer-pressuring me lolz.. :( was thinking water injection, re-route part-cooler pipe, crank up boost as next mod... And clutch when the stocker shits itself haha. Have you seen my dyno-plot, and any comments? Laggy hey.. Well I only know the stocker's response thats why I keep saying its a bit of a lag-boat.
all of the stuff on your printout is just about identical to my gtx3076 with 0.82 when i had a tune on 98pulp.
Hey thanks man, if thats the case then I should be pretty happy that it matches a top of the range Garret..and yes it does wheelspin n skate second gear on 18 inch Bridgestone Potenzas. Third as well if I give it some stick. How much torque did you make, mine comes to 736Nm if that can be relied on. And Kasko ur right, it will never be like the stocker down low but its not far off either :)
Edited by rondofj
f**k rerouting intercooler pipe..waste of time and money , water injection will fix it, my mates vl i did, 28psi of boost, before intake mani was to
hot to touch, now with 450cc of water in its guts you can touch it fine...
Its one way to fix chinese intercooler problems(eg they make good power and flow well, but heatsoak really easy..lol)
cheers
darren
Edited by jet_r31
i was making 641nm, so looks like the two turbo's are similar on that boost, not sure about the housing differences though..
its a good result though, looks like 16psi, probably needs atleast 20psi to really unleash
Well the ching ching cooler is doin a good job because the outlet pipe up till a bit past the battery tray is nice n cool, BUT once you reach the rad/fan area it heats up pretty quick all the way to intake mani. So I know its not the cooler thats why I wanted to re-route and heat wrap that bit of top pipe away from rad/fan and cam covers
Edited by rondofj
Yours honestly isnt laggy Ron, its pretty decent. Full boost threshold is pre 4000 which is decent. Peak toque isnt far off. It didnt make the 300 you hoped for but then again its close enough.
The result is pretty decent as is :)
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
