If you looking for a 3076R equivalent then go the 0.63/ 5558 which is what I did from research and Unigroup's advice, if you looking for bigger, then consider the 6XXX series...
I spent a heap of time comparing numbers on this also.
For memory when I looked at this (I dont have the numbers on me) the 6262/6266 are pretty much similar to a GT3540 and the Precision 6466 is somewhere between a GT3540 and a TO4Z# .
Obviously how these would drive will also vary based on the rear housing size/ split pulse or not etc.
All the T3/T4 ones are, AFAIK.
If you got one of their garret copy items it would have a water cooled core (IE the T28/GT30 variant stuff).
I always assumed bb chra had oil and water cooling.
I guess no one has had many issues with it though.
What did you guys do with the water lines? Just link the feed to the return with a braided line or something?
Tune all done, ran out of pump (fuel) top end so we stopped there but I'm fairly happy with how it went... May chuck another pump in and see how it goes but I'm happy for now :)
PTE 6262 on stock bottom end RB26 with a Greddy 1.2mm head gasket and Greddy drop in cams
Edited by SimonR32
Wow why u making so much power man- 450ish rwkw is it?? How much boost and no E85?
600hp at wheels? Very nice result gotta be extremely happy with that !!
Is that on caltex eflex ?
Sucrogen, we don't get E85 on pump over here :(
About 450kw at the hubs yeah, boost is on the graph 1.6bar to beef up the mid range and 1.4 bar top end. It's running E85
Awesome results mate. Hurry up and go to the drags :)
I considered cams :)
Hows it feel on the road?
Maybe, depends if I can be stuffed. Cams should make a bit more power, if you do cams I'll do another pump :)
Only drove it about it 200m, gave it stick in 1st and 2nd, held on... Was good!
What rear housing is on the 6262?
T4 0.84 divided
Very nice power! Looks a bit laggier than a Gt3582r, which isn't really that bad news on a turbo that will make as much power as this if you tried pushing it :-)
We overlayed a few GT3582R graphs and they were similar response. Remember hub dyno makes things look lazier than a roller graph and the run was only started at 3000rpm so not much time to wind up the big girl. Could make big power with another pump though, would go close to 700 if we were crazy haha
The boost isn't falling over top end either, it's just we layed more boost into the mid range to beef up the torque. If we had held that boost through it would have run out of fuel (and probably make another 30-40hp)
sorry if ive missed it, wondering if that a stock bottem end?
Yeah it's pretty clear it has plenty more flow in it - no question of that, for the lag it'll make way more than a GT3582R. I am most familiar with hub dynos, and the .82a/r T3 single scroll GT3582Rs tend to be all on by around 4300-4500rpm so barely any more lag considering the extra power but I'd have guessed it to be noticeable.
Compared with the T88 it's noticeable haha
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
