Precision Billet Turbos
Pretty much my dilemma as I was saying on the last page, going off the dyno sheet on the 3.4L there isn't much in it and the top end gains are great.
From going by there website the 6262 was the first of that sort of series then they did the 6266 which is a touch bigger, then the 6766 which is bigger then a To4z then recently the 6466 which sits midway between 6266 and 6766.
And yeah I highly doubt you would notice the 600-700rpm difference (as quoted by a precision rep i spoke to) between a 6262 and a 6466. You literally wouldn't pick it by driving it I think you would only notice on a dyno graph as above considering how long it takes to jump 500rpm at the 4000rpmk mark on even a stock RB
Are you joking? 600-700rpm is a huge difference. That's about the difference between the T88 that was on my car and the 6262 I now have.
The T88 was horrible and I mean horrible on the street and even worse at the track while the 6262 is a great little zippy thing.
Well my 6262 is better than my old T04Z but not the miracle that some would lead you to believe. The 6466 is a fair wack bigger (195hp rated), I doubt you would be getting that for nothing :)
That's why I thought I'd ask, people have claimed that the PT6262 spools better than the GT3582R which sounds unlikely but who knows. The PT6466 is not far different in measurements to the T04Z and there is no lb/min rating for them - though Precision rate them at 900hp. Does that mean they can be used in place of a T51R Kai on a pump gas setup for someone looking for a bit more power with the same or less lag? It seems unlikely to me.... there isn't even any reason for me to have confidence that they'd make more on pump gas than a T04Z.
I'm trying to determine the place of the larger Precision turbos when huge boost and E85 isn't involved.
the wheel sizes im camparison are a huge difference between the too aswell which is why i find it hard to believe that they are rating it that much laggier between the 62 and 64mm turbines
From my experience with my own engine, a certain boost pressure = very similar power level provided the turbo is still within its capabilities. When a turbo start to roll over of course the power gains decrease per psi. As you'd know pump fuel and 900hp are a mismatch (on a small engine anyway), as you will never be able to put the boost in that is required to get it in the zone.
I would certainly place my bets in saying that a 6466 will outspool a T51 donkey (sorry to all my friends who I have offended in saying that :devil: )
The test that Sound performance is a good example how different the 3 Precisions react even though they have identical exhaust wheels.
Yep, same findings here too - well except for 900hp on pump fuel, I know a few mad men who have managed 900hp (flywheel estimated at least) on pump gas on RBs. Big turbos, lots of rpm and head porting involved of course.
Hahahaha yeah you would REALLY hope it would outspool a T51R, though I would be extremely surprised if you could squeeze the same pump gas numbers out of an engine capable of it from a 6466 as a T51R.... and to be fair, would be interesting to see if the peak power numbers on race fuel would be comparable too. I wonder how those power ratings were determined...
Some of these tests make me really wish I had a dyno. A lot of these tests people refuse to touch timing etc to keep things equal, and I honestly haven't done enough first hand dyno tuning with like setups to ascertain whether this is a fair way of comparing or not. Will optimal timing be the same at the same load and rpm for every different turbo setup?
Ive also always been wary of bolt on bolt off tests that crop up. Surely charge temp and turbine efficiency alone would leave a few degrees in the lurch between models.. Otherwise what is the point of spending an absolute packet on tuning? Time to jet up our cabys and change the chip in our MSD.
Get yourself a dyno Lith :) Once you have a place to sit and tune which belongs to you the customers will start lining up.
Here are some more results from this Saturday on the dyno. We were aiming for 35psi on the next hit, unfortunately the idle speed control screw of all things decided to unwind itself. It was already 9pm when we sorted it out so had to cut it short, but I am very confident in saying that we would have seen 1150whp.
Pretty amazing how linear the power curve is since it is making drag engine power. Rev limit is set to 9500rpm.
Went for a drive yesterday (to get it licenced) and did some 4th gear flat road pulls from around 3000rpm, getting 1 bar at 3700-3800rpm which is probably a few hundred rpm better than my old GTR with a T04Z with similar top end power capability. Makes for a savage car on the road, pulls long and hard through the gears and is an absolute bullet.
Going to go back on the dyno after I sort out a second 044 and run it up again holding 1.6bar through the revs, should go 650hp (485kw) fairly easily by the looks :)
nice...
can you post a sheet? couldnt really see the figures prop.
where was it coming on boost?
guys, i seem to be blowing out a bit of blue smoke on hard acceleration and shortly after
just wondering what could cause this
i am running -4 feed as per precision's recommendations and a hardline drain to -12 hose to the block
i thought precisions had in built restrictors or do i need to put one in??
Is yours BB or JB? And are you certain its oil smoke?
Check cooler plumbing and plugs for signs of oil leaking from the compressor side. Most leaky PT threads I have seen are comp side and the leak can be seen on idle with the pipes off.
  • 3 weeks later...
    • Nah, yeah, nah. Speakers have a nominal impedance of 8 ohm that looks more like 6.4 ohm when measured. The receiver's amplifiers (all channels) are all rated to 6 ohm (I think, it's been a long time since I cared). The real problem is that many modern class D amps have aggressive protection circuitry that cuts off the fun if they think too much current is being drawn. And with my speakers having series crossovers, as opposed to more typical parallel crossovers, and big TL enclosures, they can certainly dip down to lower impedances at some frequencies and that easily triggers the protection. Pioneer receivers are somewhat famous for it, but even Denon, Onkyo, et al, all have many complaints against them across various models. It only does it when listening to music at high levels. You have to be putting your ears at risk to do it. But sometimes I want to do that. If I was serious about using it as a listening room I'd simply upgrade the amp for the front pair to a nice Rotel or something, and just use the receiver for signal handling and processing - although that would be a bit of a pain in the arse too. Have to switch on more shit, pre-amp volume vs main amp volume, etc etc.
    • yeah pretty much, stopped playing after lightfall, couldnt be bothered with the final shape...  ran that game into the ground for years... bit of a shame.. the  story was awesome. was playing a lot of trials but the hackers became tooo much, ruined the game.
    • This is why you don't get invited to press events.         Kodi
    • For example, you’ll need this approval if: you’re a car enthusiast looking to import a specialist vehicle or an older car you want to bring your vehicle with you when you move to Australia you manufacture or import special purpose vehicles or a small number of trailers each year.       Tutuapp 9Apps
    • I reckon you are 100% right on the money. The only reason I bought Red Sport instead of the base VR30 is that I am investigating racing it in Production Cars, and they require you to run a (mostly) standard car....therefore knowing exactly what was in the RS spec was important to me and I paid the extra. Other than that, for sure I would have pocketed the $10k and spent them on mods instead. Plus the non-RS models are more likely to have had a nicer life prior. Just a warning though, mods always cost twice as much as they look like they will on paper BTW you should also consider the 400R imports, they are about the same price as a local RS but 5+ years newer. Of course that comes with the usual warnings about finding parts, unhelpful nissan dealers and finding insurance
