Depends if he is running E85 or not, my 6262 went 450kw on a hubber running E85 with baby cams. When it was making that power top end it was only running 19psi.
I'm sure on 98 you should go close to 400rwkw on 20-22psi with a 6262
Got a new fuel pump (Magnafuel) that arrived today... Getting it all ready tonight and hopefully back on the dyno tomorrow.
See how it goes on 1.6bar throughout the rev range, hell if I get cheeky might go 2bar and go for 500kw :)
Do it. You won't do it. :P
myengines back in the car, 6266 is bolted on and custom oil/return lines made
just waiting to finish the dump and intercooler pipe then its turn key, wont be atleast afew weeks till its tuned to post results (on e85)
simon R32 keen as to see your results mate, whats the flow difference between the walbro e85 and ur new pump?
Walbro 355L/hr at 70psi and the Magnafuel Protuner 625 402L/hr
Walbro is so much better... Smaller, lighter, quieter and cheaper but can't be used externally so I had to look at other options.
Fired up the Magnafuel tonight, it's pretty loud (would be louder than a pair of 044s) but it should do the business
Did you replace the Walbro due to outright flow or lack of stability in pressure...or other reason ?
I had a Walbro in the Green car, was perfect. The GTR had a surge tank and Bosch 044, it ran out of flow so I needed to go either twin 044's or a big single pump, hense the Magnafuel getting the tick.
Hey guys, Nearly D Day for my GTR to jump on the rollers With the 6766 CEA & e85. Be Interesting to see what Jez can do with the beast Dont think hes tuned something this big as yet Maybe, except for the T88 Top Secret GTR.
I bet Alot of you guys are wondering what the 6766 can do on a Built RB26, Well I havent seen what they can do as yet anyways. shes got big cams in her so will be interesting 280 11.5mm Lift Just hope the engine likes the boost that these turbos produce.
Twin scroll ryan 4inch inlet & 3inch out from memory. Has 3.5 inch exhaust but not that thats going to matter its coming straight out of gate so should sound the goods lol.
What comp ratio is the engine? Any tricky headwork?
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
    • I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
