Precision Billet Turbos
Detonation on pump fuel would also depend on cam/headwork too. As larger duration camshafts would lower dynamic compression. You may find some cars that have been built very well may make a lot of power and only gain a rather small amount(in comparison to others) when switching to E85/C16. Your limiting factors would be the small exhaust housing/pump fuel/standard manifold.
Standard mani-mick o has made 340rwkw on e85 stock mani low mounted, mafia did 320rwkw low mount 3076 0.63a/r, theres been others in this power range with stock mani so I would tend to think its not as limiting as the pump fuel n housing
Yep Mafia had wmi, check out the new manifold thread- scottynm35 said someone just made 430rwkw throught a stock mani on an RB- hes a pretty respected fellow here and theres no reason to doubt his claims.
Same here - Tuned by Jez, SR20 GTX3071 0.82 limited by knock on 287kw/18psi on 98 pootral.
Unfortunately its E85 if I want to go more.
Anyone tracking a car that close to the knock threshold on petrol needs to get ready for a new tractor engine imo. Considering I made nearly 60kw more on the same turbo with an auto, and was nowhere near the knock limit...
"Unfortunately?" what have you got against e85 anyway?
"Unfortunately" the stuff is in poor supply in NSW.
I kind of like being able to fill up when I need to, rather than have a car only capable of blasting around my own block and needing a trailer and jerry cans to go to wakefield (3 hours drive out of Sydney, where most of us live).
That attitude is probably why there are no pumps getting installed. :P
Ha. Troll.
You made 60kw more on what kind of boost? 26/28 pound wasn't it?
Jez knows I flog the car, and thus it is tuned accordingly.Wouldn't have lasted 2 full wakefield days if it was on the limit. I know its hard to remember a time before E85 for you, but people still did track cars back then :P
  • Like 1
A lot of people wanting to see a 6466 on an RB26 dyno sheet... I will post this pic and vid but keep in mind it's not finished yet. The 6466 turbo is pretty awesome. We did an overlay of this turbo compared to the old setup (twin GT28-10's) and the car makes heaps more torque and power in the mid range compared to the twins.
583kw on 30psi
Precision 6466 with 0.84 rear
6 boost mani with 50mm turbosmart gate
280degree 10.8 Tomei cams, bigger valves, springs, retainers, porting etc
E98 Ethanol from Powerplus
Tuned by Trent @ Chequered Tuning (0414 944 146)
Still running off wastegate spring pressure (no boost controller), hits 23psi at 4500rpm. Needs a larger gate because it starts to creep up slowly towards 30psi (hence the increasing torque curve). Holds 30psi after about 7000rpm til redline so we can probably run more boost after the ignition is upgraded (blows out spark above 30psi). Definitely more left in it.
  • Like 1
583kw on 30psi
That is a fantastic result! Very nice, thanks for sharing!
  • Like 1
Cool. what rear housing are you running on the 25/30 and are you retaining VCT?
Very impressive results! Here is a progress picture of my 6466 mounted on my 30/25 motor. Motor was getting put back in today and I got a quick snap
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back to our newest location for our Sunday morning coffee catchups! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 10th November Meet Location: Baybreeze Cafe - 2 Wellington Street, Sans Souci (entry via Plimsoll Street) Meet Time: Meet at 8:00am Map: https://tinyurl.com/sausundaysession-baybreeze This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
