Precision Billet Turbos
We'll, forgive me for being a sceptic, but I need to see a timeslip or data log to believe. This thing still makes 200 ftlbs more than I thought possible and spools earlier than a 35r. Crazy!
Did you see the boost level it is running? Most RB26s aren't running nearly that, and it is twin scroll which is capable of boosting torque "per psi" versus a single entry... all works well towards making a lot of torque.
In terms of spool, to be honest it did surprise me too - but it is definitely worse than GT3582Rs, particularly than twin scroll ones (keeping it apples vs apples).
More things to consider - if we were to give all these turbos names to match Precision's ones (using wheel sizes) it may put into perspective how big a PT6466 is (or isn't) considering what it can make:
GT3582R - GT6162R
GTX3582R - GT6362R
PT6466 - PT6466
T04Z - GT6765
The 66CEA turbine has by reputation less lag and more flow than the old 65mm T-series Garrett design as well, and the compressor is a light billet wheel - so really for the size they should spool at least as well as a cast wheel equivalent... ignoring aerodynamics :)
Fitting somewhere between a GT3582R and a T04Z really shouldn't be too surprising, which is why it's magic that it's a 600kw @ wheels capable turbo :D
Also worth noting that the 6466 a few pages back looks similar on Chequered Tuning's dyno:
Be interesting to overlay that and the new Hypergear "ultimate" 500kw turbo
Nice work! That is an awesome power delivery, and more in it is always a bonus :-D
SCR48 is in Perth, silly me. Be interesting to compare the results, what are the odds two 2530/6466 setups would be tuned on the same day?
That was my car.
Couldn't go past 27 due to needing to up the breathers on the rocker covers and mainly from frying tyres on the dyno
nice result man. what rpm was it letting loose on the dyno? given that likey abit more than what thats reading
pretty linear from the 4700rpm mark! almost flat lines
Edited by Frosty
nah he is QLD hick like the rest of them :P
My main thing was that i wanted it be strictly streetable and wasnt fussed about the dyno figure - not that its too bad at all! Therefore I went for a 6466 with .84 twin scroll - I was concerned this would be too big as I was thinking to go for a 6266 originally - although very happy with this setup which is super responsive compared to most cars I have been in, not to mention torquey-as down low due to the RB30.
It has been running for some time on 13psi run in tune which it did 308rwkw on pump 98 - then 20psi on e85 which it did 365rwkw for about 2 weeks.
Even on 20 psi the car is a wild drive on the streets - stepping out in 4th gear once is hits about 4000rpm as if it was second gear (still waiting on half decent tyres to show up).
If I upgrade the catch can (which is small as I wanted it to be hidden) they could push 34psi but doubt I will ever need to, nor bother going to the troubble as this thing has been in the making for over a year now!
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
