Precision Billet Turbos
I know it's the shittest pic in the world but this should give you an idea of 6262 power potential. We ran it up at just under 2 bar (1.96 I believe) and it went 710rwhp (530rwkw) and 776Nm.
Stock bottom end RB26 with 1.2mm head gasket and Grex 9.1mm cams
Fark! :blink:
Still running the 1200cc injectors or have you upgraded?
Why do you post this result you will destroy my wallet!!!
Holy molah!
*chucks the twins in the bin*
I know right hahaha
Awesome result man :D Got to be happy with that, had no doubt that a 6262 would make that kind of power but still cool to see somewhere here throw it down in a GTR along with a decent power delivery :) Going to be an animal!
I am rapt that people in Oz are embracing these (Precision CEA and FP HTA turbos), I wish people in NZ would join this decade too :(
I have been prattling on about them for YEARS, and just get chortled at like people think it is inflated dyno results or whatever. Had a bit of that a few years ago on this forum but now it's the new black.
  • Like 1
Its a damn good result and to be honest that dyno figure would be quite conservative as well.
We get the 200SX tuned by Yavuz and at about 430rwkw i have run 137mph at Eastern Creek in complete street trim. I am talking stereo and all, so with a 484rwkw your most certainly going to be running into the 9's at over 140mph
I am really looking forward to seeing what the 6766 twin scroll does on our car now. I got a 1.0 rear so it will be interesting to see just how responsive it will be
With regard to traction, throw a couple of washers on top of the diff mounts and point the nose of the diff down ie between the diff and cradle. Made a pretty massive difference to the car after we did that. I know it can be fun to drive without them, but nothing beats being pinned back into the seat and not being able to move :)
My main thing was that i wanted it be strictly streetable and wasnt fussed about the dyno figure - not that its too bad at all! Therefore I went for a 6466 with .84 twin scroll - I was concerned this would be too big as I was thinking to go for a 6266 originally - although very happy with this setup which is super responsive compared to most cars I have been in, not to mention torquey-as down low due to the RB30.
It has been running for some time on 13psi run in tune which it did 308rwkw on pump 98 - then 20psi on e85 which it did 365rwkw for about 2 weeks.
Even on 20 psi the car is a wild drive on the streets - stepping out in 4th gear once is hits about 4000rpm as if it was second gear (still waiting on half decent tyres to show up).
If I upgrade the catch can (which is small as I wanted it to be hidden) they could push 34psi but doubt I will ever need to, nor bother going to the troubble as this thing has been in the making for over a year now!
    • So next year I am looking at upgrading from my VE SS bomadore ute to something more refined.  I wanted to stick with a V8 but not anything German or Australian, either a coupe or a sedan. So if I wanted anything newish that limited my options to either the Lexus RCF which I quite like. But with the price they demand and a kid on the way a 2 door coupe is probably not going to be the best idea. The next best thing would be the ISF but the newest models are 2014 and commanding over 60k and even the older 2008 models in ok condition starting around 35k is kind of bullshit. So I figured if I could not have the noise I could perhaps make do with easy power. Enter the infinity Q50 or Skyline equivalent. The price difference between the 300 and 400hp models seems a bit crazy. Right now there is 300hp Q50 one on carsales from a dealer with 61km for 27k drive away. If I wanted to get a 400hp Red or 400R car the prices seem to start at 43k From my limited research it seems that the only differences are that the 400r/Red Red runs more boost and a more aggressive tune. There are are turbine speed sensors on the turbos. Has 2 pumps for the water to air intercooler. Runs an engine oil cooler. I'm guessing that the exterior trims might look a little more sporty as well. I had a lazy look for upgrades to bridge the gap on z1motorsports They have kits that upgrade the water to air heat exchanger as well as the coolant pump which should give a non Red/400r better intercooling temps than the stock Red/400r. I added an engine oil cooler with a thermostat as well to try and make things as close as possible. Obviously the ECU is going to need a tickle. Having not done much in the way of research they also sell a ECU flashing tool with pre loaded tunes that are supposed to boost the non Red/400R by 100hp which adds 1k USD to the cost. The total cost of the parts @ the current time including shipping and taxes worked out to be $4350 AUD. Personally I would rather get the car tuned on a dyno which would probably add more cost Assuming the worst that you got a workshop to install the new parts I would guess no more than 5 hours would be required in the worst case @ 5 x $150 per hour = $750 So the total cost could be around $5100 So for easy number 5k + 27K = 32k I guess that would leave some change left over to swap out the open diff and fit a LSD Any thoughts?
    • Right, not sure why I thought it to be a lean spike. It might be fixable with modern card-style hot film MAFs which have some design features to avoid counting reversion flow but I've never tried it myself.
    • I did not realise this, I'll contribute more and earn my stripes and retry later.
    • I'm only going to hassle you for posting links to images. It's against my policy to click links that could be some nasty payload. Sadly, you need to make 9 more posts before you can just stick the images directly in a post, unless @PranK sees this and bends the rule for you.
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
