I know it's the shittest pic in the world but this should give you an idea of 6262 power potential. We ran it up at just under 2 bar (1.96 I believe) and it went 710rwhp (530rwkw) and 776Nm.
Stock bottom end RB26 with 1.2mm head gasket and Grex 9.1mm cams
Posted Image
What an effort, that stock bottom end must be loving you for it....
This seems a lot more than I would expect out of a 6262, was this on a hub dyno? Impressive effort either way.
Its in line with what I would have expected on a hubber - if not still a little shy of potential. I'd expect a cranked up 6262 to be able to crack 500rwkw on a rolling road, too.
That was just a single run, tuner actually wanted to go harder and felt there was still more left in it but standard head bolts didn't want to play ball. Have replaced with ARP2000 studs this morning.
It trapped at 135mph with around 640hp on the same dyno so would expect around 140mph now
Given that I've seen 491kW out of a plain jane GT35 on an SR and backed up with 147mph in a full weight 180SX, I would expect a 6262 to push over 500rwkW. I don't know how much over 500 it would do, but I guess the 6262SP was the one that put Precision on the map with a couple of EVO's that were trapping over 150mph and one into the 8's, that was enough to suck me right in back in 2008! :)
By the way I have a 6466 sitting here unopened in the box with a .84 T4 divided housing, it's been sitting here while I contemplated testing one on my own car but I'm going to pursue with what I have for now. PM me if interested.
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
