Precision Billet Turbos
I looked around for this information for a while too, and finally when throwing out the shipping box for the turbo found that the information was actually in the box.
Here I was thinking Precision shipped turbos with no information like Garrett do.
There is an inner and outer box, and al the necessary information I needed was between the two. Tear you box apart and you'll probably find it too, along with stickers etc.
If there is one thing the Precision vbands could do to improve their setup, it would be to make the vband positively centre on the housing by machining a matching edge on the housing and flange. Such a simple thing to do, and it greatly improves the seal, load carrying capability and guarantees pipework is centre off the back of the housing.
I thought the same about the vband Ian but I've been playing with it and on mine at least when you tighten the vband it centres perfectly. I would still prefer to see a stepped fit though.
Looking at a 6266 for my 25 neo. What vendor has them at the best price? Best ive found is about $1800 delivered for a t4 divided .84
exchange rate isnt working in your fav currently. Have you tried mercury or powertune for the local distributors?
Try and get a quote from Raw Brokerage (look for Ricky, tell him the RB'd G in Dubai sent you lol). I got the same exact one a few hundred dollars cheaper.
Well looks like we're starting to come close to what the 7175 is capable of in my car, there's a couple more things we'll try first before we possibly switch to something bigger.
Tapped 51psi a couple of runs and with the car trapping 164.5mph and weighing in at 2670lb it's showing around 925hp at the wheels, Precision rate the turbo to 985hp.
http://www.youtube.com/watch?v=xSBivS5qmpc&feature=c4-overview&list=UUCVe2Q-x7n-mDvtT1rrV9cg
This is more of a blog / video of the day, don't think you can view it from a mobile.
http://www.youtube.com/watch?v=zijeh6axvyc
well and truly flowing more than the 985hp they are specifying then. Congrats on the build man
Thanks guys, I'll make a decision after next time at the track.
Nothing special on the head other than George from Advance decked it by hand with a stone block. No one believes me!
LOL Darren! I don't know what point it will need something special, we'll see if we can squeeze another 5psi out of it.
Then 7675, then 7685, then 8285 all in??..f**k it..just go straight for the Pro-mod..haha
The Precision dude at jambo didn't like it when i asked him when the 80mm turbines are coming back
theres some big holes left from the 7680 and 8280
cheers
darren
Edited by jet_r31
Well, my mate has an 8285 with a .98 housing machined up, it will go straight onto mine, so if I'm going to put a track turbo in, it will be that. I can't even imagine how that would feel on my engine when it comes on....this one hits like a train as it is!
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
    • Mmmm. Perhaps more correctly stated that the one turbo doesn't actually force air back down the throat of the other. All it does, and all it has to do, is be pumping a little harder than the other turbo (which is an effect of how the turbos are getting driven by the exhaust and inherent resistance to output air flow that each turbo sees up to the merge). If the turbo that is not flowing quite as much then nudges the stall line (because it gets pushed there by the higher flowing one stealing the limelight and moving its own operating point further from the stall line), then you get the behaviour described by Josh. There is no need for air to move backwards in any way. It just needs to be less air moving forwards than is required to stay to the right of the surge line.
    • GTX2860R Gen 2 is an option. No, it doesn't actually do much. The basic problem with wanting 600 whp out of the factory twin turbo setup is a few things. One is that the twin turbo piping is just so, so inefficient. The front and rear turbos are not actually working evenly. The rear turbo is always moving more air than the front. On top of this the OEM rear compressor inlet is rubber that likes to collapse causing a huge intake restriction. The merge doesn't even wait until the intercooler to happen, and it happens at a 90 degree angle. This is why you see some discussion about "turbo shuffle", where in certain conditions one turbo can actually force air to go backwards into the other compressor and stall it out, then once the other turbo recovers it stalls out the first turbo in a cycle until you do something to break out of it. The other issue is that the RB26 is just not that efficient an engine. It needs a surprising amount of ignition timing to reach MBT for a given cylinder pressure so all that time in which the cylinder is pressurizing before TDC is just wasted energy. An N54 might be around 10 degrees BTDC on a stock turbo getting into the boost. An RB26 is closer to 25 BTDC. Net effect is a turbo roughly the size of what HKS uses on the GTIII-SS (smaller than the R3/GCG Japan "GT2860-1" -7s) is only good for maybe 550 crank hp or low 400 whp while a roughly comparable turbo on an N54 can deliver something like 700 crank hp and obviously drivetrain losses are greatly reduced when you aren't burning a bunch of power on keeping a hydraulic pump + transfer case preloaded all the time. So yes, you can make a lot of power but there's a reason why people go single turbo for the numbers you're asking about. Don't forget that the RB26 can't even do a straight line pull without oil starving on the stock oil pan either. Baffles can help, but really you just need more oil capacity.
