Nothing that hasn't been done before Darren, Just not on a street car! As long as it doesn't fall off boost between gears it should be ok, remembering that can rev this to over 10 grand if I have to, I'd prefer not to though.
  • Like 1
I was about to say "Now you're just starting to get silly..." but really, that happened quite a while ago. That thing is a beast to watch, was glad I got to see it running in the flesh!
Should have said hi, Lith. Unfortunately I wasn't on top of things with the boost control at WTAC, the street and circuit grip level was completely different. Before the hairy last session we even took it outside and tuned it to full traction, then turned it down again for a bit of assurance.
It turned the tyres on the first run, so in between runs, not being able to look over the log, I took a stab at what speed I thought it was breaking out. What I ended up with was 22psi all the way half way through 4th to an agro 45psi which lit the tyres up. Being such a big event rather than pedal, I mashed it and held it flat, and a slight over correction when the front wheel speed was doing 220km/h and the back doing more like 260km/h sent me facing the walls....at least the crowd loved it!
We are revving it to 9000rpm over the line at 164mph.
PTE don't make a TS housing yet, I was speaking to Harry when he was here for the Nitro Champs and they don't feel the demand is big enough.
I actually headed past your area a couple of times to say "Hi" but wasn't sure who you were and the moment didn't seem right for a random to push in and say "Who is PJ???" - then next thing I knew the weekend was done, it really was a blur of an event.... went past so quickly it wasn't funny. First trip to Oz was a goodn' and I'll be back, hopefully just get to see an even crazier S13 :D
nah, we havn't, i was walking next to Maatouk at jambo and turned around and saw you, was just about to introduce myself
when Anthony turned around and said PPPJJJ and started talking to you, i just walked off as i had only just met Anthony but
already worked out 2 things,once he starts flapping his gums, i could have been standing there for hrs waiting to talk, and 2
if he ever gave up on working on cars, he could probally make money of a stand up comedy gig..lol.
maybe next time lol
cheers
darren
Just ordered my 6262 with a T4 twin scroll .84 v band rear and the 4 inch surge slotted front.. lets see just how strong a standard 25de neo really is with 10:1 comp and e70
Aww shit, this should be interesting. Or hilarious. Either way, exciting :P
still ecu and the stupid stupid expensive job of doing turbo lines and fuel lines which is gonna be a surprise $700 in fittings and hose.
Looked at the AI industries surge tank with twin 044's today too but thought f**k it single intake walbro it is!
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
