Nothing that hasn't been done before Darren, Just not on a street car! As long as it doesn't fall off boost between gears it should be ok, remembering that can rev this to over 10 grand if I have to, I'd prefer not to though.
  • Like 1
I was about to say "Now you're just starting to get silly..." but really, that happened quite a while ago. That thing is a beast to watch, was glad I got to see it running in the flesh!
Should have said hi, Lith. Unfortunately I wasn't on top of things with the boost control at WTAC, the street and circuit grip level was completely different. Before the hairy last session we even took it outside and tuned it to full traction, then turned it down again for a bit of assurance.
It turned the tyres on the first run, so in between runs, not being able to look over the log, I took a stab at what speed I thought it was breaking out. What I ended up with was 22psi all the way half way through 4th to an agro 45psi which lit the tyres up. Being such a big event rather than pedal, I mashed it and held it flat, and a slight over correction when the front wheel speed was doing 220km/h and the back doing more like 260km/h sent me facing the walls....at least the crowd loved it!
We are revving it to 9000rpm over the line at 164mph.
PTE don't make a TS housing yet, I was speaking to Harry when he was here for the Nitro Champs and they don't feel the demand is big enough.
I actually headed past your area a couple of times to say "Hi" but wasn't sure who you were and the moment didn't seem right for a random to push in and say "Who is PJ???" - then next thing I knew the weekend was done, it really was a blur of an event.... went past so quickly it wasn't funny. First trip to Oz was a goodn' and I'll be back, hopefully just get to see an even crazier S13 :D
nah, we havn't, i was walking next to Maatouk at jambo and turned around and saw you, was just about to introduce myself
when Anthony turned around and said PPPJJJ and started talking to you, i just walked off as i had only just met Anthony but
already worked out 2 things,once he starts flapping his gums, i could have been standing there for hrs waiting to talk, and 2
if he ever gave up on working on cars, he could probally make money of a stand up comedy gig..lol.
maybe next time lol
cheers
darren
Just ordered my 6262 with a T4 twin scroll .84 v band rear and the 4 inch surge slotted front.. lets see just how strong a standard 25de neo really is with 10:1 comp and e70
Aww shit, this should be interesting. Or hilarious. Either way, exciting :P
still ecu and the stupid stupid expensive job of doing turbo lines and fuel lines which is gonna be a surprise $700 in fittings and hose.
Looked at the AI industries surge tank with twin 044's today too but thought f**k it single intake walbro it is!
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
